I'm planning to replace stock summer and winter tyres on my T6 Transporter with all season tyres. I plan to fit 235/55 R17. Van is used for work, so I would want to keep within manufacturer specs, but I'm slightly puzzled by OEM suggestion of fitting 235mm tyres on 7-inch rim. From what I...
Hi all, newb to forum here. I’ve read loads and all I want is a simple yes or no answer. I would like to put 225/70 R17 7J tyres on my standard 2022 T6.1 4motion. Will this size of tyre cause rubbing anywhere on the van?
Wheel & Tyre Info - T6 Range
These posts are intended for basic information covering the T6 fleet that should hopefully answer lots of initial questions about sizing and fitment
If you have any info or think anything should be added that could benefit then please post it below and i will edit...
