Considering going for a set of these...anyone want to guess at the tyre size fitted to the one in the pics?
I'm running Bilstein B6 and Eibach springs wondering if I could get away with squeezing a 235/55 on, or stick to 255/45...
Folks,
I have a 2018 t6 highline originally factory built on 16” rims.
I have upgraded the wheels to 20” and also the front discs and callipers to 340mm.I’ve been told the 16” spare will not fit now.
question does anyone know if the spare wheel carrier will accept a 17” rim shod with with a...
I’ve tried searching but can’t find definitive answers…
I’ve Picked up a new set of amarok posadas which are 49mm offset.
My question is, after the standard 235/55/17, what is the next size larger from these that most people run?
I don’t want to go as big as 245/65/17 for scrubbing and...
Our new ocean is due in about 6 weeks time. Can anyone recommend an all terrain tyre, similar to a BFG AT that will fit the 18inx8J Teresina Black Alloys that we have coming with the vehicle?
Thanks in advance
There are plenty of options according to the online tyre calcs but I'm curious what people are actually running?
My preference would be to go a smidge oversized both in terms of radius but also width (to get some rim protection but also because I don't like the 'stretched' tyre look). Probably...
I am trying to spec up the types to go with a set of Zitto 935 18's. They are 8.5J wide.
Custom Vanz and others are using 255 45 R18's is this the best spec, or should I consider something else?
Also which brand-model do people recommend, I am inclined to go with the big brands but...
Wheels I am after are currently only available in 19's with 8" wide. Was originally heading for 20's but stepped down to get what I wanted but now the drop to 8 as well and I am waivering. I see the can run with 245's which is probably okay but don't know a great deal on alloys. I was just down...
I have a T5.1 shuttle and have some modular steel 16x8 8J et25.
I have put some BFG KO2 on at 235 70 16 but they foul the front calliper so will need spacers on.
they fill the arches well at the moment so would like a smaller spacer as possible.
Does anyone have a similar setup with 10/15/20...
Hi guys I am really liking some wheels from JBW.
The spec as follows
8 x 20, et 45, correct pcd load rated etc
I like the spec as my sport line wheels are 8” and et 50 although sit in a little bit much for me so thinking these should drop straight on and look good with no issues of rubbing...
Hi Folks!
Looking at new wheels/tires for T6 Highline. Sticker in the door only provides one size for 18inch wheels, which is:
255/45 R18 xl 103H 8jX18
What rims widths would you recommend for each of these?
Which tire would provide the most comfort and less road noise?
Current on 2015/65...
Wheel & Tyre Info - T6 Range
These posts are intended for basic information covering the T6 fleet that should hopefully answer lots of initial questions about sizing and fitment
If you have any info or think anything should be added that could benefit then please post it below and i will edit...
