adjusting coilovers
  1. LambethBoy
    Wanted Bilstein shock spanners
    Has anyone out there got a set of these? I’m looking to adjust my original B14s. They’ve been on the van since 2018, still holding up well just need these for a little job :thumbsup:
  2. Chilli Jam Vans
    New TMP 16XL comfort coilovers - new to the UK market
    Something a bit different that's recently been introduced the market is this TMP 16XL comfort coilovers. Amazing bit of kit, TUV approved German quality like all the Twin Monotube Projekt lowering and lifting products, and we are offering free fitting for anyone interested in these and willing...
  3. chappers0987
    Bilstein B14 Komforts Adjustment
    Hi all, I’m looking to raise the ride height of my van by 10 to 15mm, I currently have B14 Komforts fitted lowered 65mm, however the height from the floor to bottom of the front bumper (when parked on a level surface is 120mm) it is causing me kerb / speed bump anxiety! The front coilovers I...
  4. Eli
    Suspension needs tweaking
    So the van lowered on HR Koni’s but the suspension needs tweaking. Currently the front is on 370mm and the rear is on 400mm. Question is do I bring the rear to match the front or front to match the rear bearing in mind it’s a Caravelle?
  5. C
    How high is too high (when you're low)?
    My van came with a set of H&R coilovers installed. I'm 99% sure they are the standard drop ones: https://still-static.com/product/hr-normal-coilover-kit-for-vw-transporter-t5-6-t32-f-50-80mm-r-40-70mm-bilstein-front-bilstein-fixed-rear-clamp-hub-brackett/ I'm not a fan of having a huge drop on...
  6. Thatratman
    Adjusting the rear coils of H&R's
    Hi all, I see this has been mentioned on a few other posts but I just want to check I'm doing the right thing.. The rear end of my t6 needs dropping approx 10mm to sit closer to being level with the front, I'm planning to do this on the drive at home with jacks and axle stands. Is it as simple...
  7. peteslack
    Adjust rear suspension? Stance+
    My van a T30 was lowered by the previous owner and by the looks (purple) has Stance fitted. Since conversion to camper have developed a saggy rear end ..... Advice appreciated on how to raise the rear ride height by say 20mm to match the front. Front measures 395 wheel centre to wheel arch...
  8. F2JON
    Bilstein b14 height adjustment
    So I’ve had my b14’s on a few months really happy with them but when they were put on they left 25mm on the thread adjustment, since going from 20’s to amorak steels I wanted it lower so today I’ve wound them right down, my question is WHY IS IT STILL THE SAME HIEGHT ?? Surely 25mm in the...
  9. A
    Adjusting Bilstein B14
    Hi all, new to the forum, had a sport line T5 previous now in a T6 high line 150. I have Bilstein B14’s on, anyone got pics of them as low as they go? I have 20’s on staggered, wanting it as low as possible. Got a pic of how it is now. many pics would be great with yours all the way down
  10. Dave F
    Adjusting B14 for towing
    I need to lift the back as I’m towing so just won’t about a 30mm lift on the back as you can see in the picture it sits a bit lo on the back. Do I turn the nut so it’s 30mm up from where it currently is?. Also I have miss placed the adjusting spanner’s so can I do it without them?. Last of...
  11. A
    [Guide] Adjusting Front B14s
    Annoyingly, although I ordered the replacement bolts for the lower rear shock and ARB clamps a week ago, the seller has just notified me that they’re only just posting them today, so the van remains in the garage on jack stands unable to be used for a few more days. With this in mind, I’m...
  12. Jollyvan
    Adjusting B14 Rear.
    Does anyone know what one turn of the adjuster represents in height adjustment at the hub. I need to lift the rear by about 20mm to get back to equal arch gap. Also van was set up level before conversion i.e. empty.
