air-con retrofit
  1. 22jeffers
    alpinair.co.uk Air-Con Retrofit Temperatures??
    Hi all, has anyone on here had their air con retrofitted in their T6 by www.Alpinair.co.uk that can tell me what temperatures they are getting out of the vents? I’ve had mine done and I’m getting 16.4 degrees from the drivers vents and 19.5 degrees from the passenger vent!!
  2. Bathaudio
    Installing Aircon in a T6 help!!
    Hi All, I have got a startline T6 without Aircon and am looking to install it! I have purchased a full system from a T6 same year. Has anyone got experience in this and is there anything I should be aware of =] TIA!! Sam
  3. M
    Retrofitting rear AC to SWB T6 Shuttle
    Hi I have recently bought a SWB 2016 T6 Shuttle and didn't realise it didn't have AC in the rear. I have it in the front but would like it in the back as well. Is this something that is possible? Has anyone attempted it?
  4. Adam_T6
    My Air-Con Retrofit thread
    Hi, I have started collecting parts to retrofit air con to my van. Has this been successfully completed by anyone? I see it is commonly done on T5s but only an aftermarket kit is fitted by Alpinair to the T6. Does anyone know of any other parts required or have any wiring diagrams etc...
  5. T5SUG
    Caravelle rear AC
    Have a 66 plate SE spec Caravelle with air con. My question is does the air con not get through to the rear vents in the back? Is the seperate rear heater not connected to the air con in the cab ? Kids have been moaning there is no air in the back
  6. Jez
    Air-conditioning retrofit?
    Hi there. Has anyone had rear air conditioning reto-fitted by VW or aftermarket. I need to know if a bigger compressor is required to handle to the extra load eith from the factory or when retro-fitted. My 16,000 km (10,000 mile) van's compressor has packed it in and I would like to retrofit a...
