Hi folks, I have managed to smack my A/C compressor right on the plastic connector.
Does anyone know a part number for this?
It looks to be replaceable on its own, held in with a circlip.
Thanks!
Hi all, Got my t6 aircon regassed but still not blowing cold just lukewarm and no errors showing the computer. When I look down the engine where the belts are the clutch isn't pulling in. Any ideas Thanks Sam
Good morning,
My AC suddenly stopped working recently, while my van was being serviced at Vw specialist in Rochford 3 weeks ago, I had them look at it and they said it just needed re-gassing and the AC was working ok, but last week while in Cornwall it’s already stopped working again.
Has...
After a week driving through France in some extremely hot weather I've realised the air con only blows warm air... any recommendations on after market air conditioning units to get some proper cool air or does the currently system need cleaning, recharging or fixing
My air con seems to have an issue. Settings 1 2 and 3 I get no cold air but on setting number 4 it is like an ice box.
Does anyone know why no cold air comes out in the first 3 settings but works fine on 4? it defiantly works on 4 and is ice cold so can't be lack of gas. Thanks.
Hope I am in the right section - looked and couldn't find any answers to this - T6 2019.
The blower for the heater works initially on all speeds and heat/air conditioning - air comes out the right vents.
However travelling through Spain/France in indicated 34/36 degree heat, with the air...
Hello all,
I recently bought a T6 and I'm having issues with the air con not getting cold at all.
It's had a regas without success so I scanned with carista and have the following 2 error codes:
Heater & air conditioning:
9471509 - Center vent temperature sensor: Open circuit/short circuit...
Just joined the camper group and got a t5.1 2013 T30 T5, however given the nice weather i started using the aircon.
This was intermittent and after replacing the pressure sensor and a few other bits i turned my attention to the controls.
In positions 1&2 i could select the aircon button...
I’d say mine needs to be at 9 o clock position (well into the blue) before it feels cool. All the way into the blue never feels ice cold. Does this sound normal ? Or do I need it checked (whilst still in warranty) ?
Went to get re gassed but as soon as they did a bit it went straight to full, so was told it could be blocked. There anything I can do or check myself? When I search for what this could be I’m not finding much for T6s
I'll admit I can only be certain this works with my T6 TSi manual...
Move the air con temperature control off the coldest temperature and voila.. Start/stop works at the first junction on the journey instead of about an hour into the journey.
Of course this may actually have a detrimental...
Removed from T6 LWB 4M (2018 - 50k) by VW. Rear air con unit, pipes, ducts, vents, rear quarter panel, dash control (no other electrics). Tested as working when removed. Retrofit or Spares. Collection only (Taunton). £450 ono (wont split).
The aircon on the T6 was possibly the strongest i have experienced but after some front lower arms suspension work my aircon was mysteriously degassed... I have had it regassed at £180 as its front and back aircon but by teh time i got home from garage it was degassed again. The garage is happy...
I’ve never really used the air con on my T6 since I’ve had it but just recently due to the weather I’ve had it on. It works just fine whe. I’ve used it for small periods of 10-20 mins.
Compared to my car though I’ve noticed that there is never any water on my drive after the air con had...
I asked this a while ago, but never got an answer. Is there a camper conversion company that incorporates rear air con? I'm curious as the California has this and it is a life saver for the rear passengers.
Hi everyone,
I’m hoping I’m not the first person to have this issue, I’ve just bought a T6 kombi and picked it up today.
It has a plastic bulkhead with a glass window in although it does have 2 cut outs at the bottom for longer items to be transported.
Behind the bulkhead, it’s been sound...
Hi there
My van is a 2016 euro 5 engine and have a noisy ac compressor pulley. Been told I have to buy the complete compressor but does anyone have a link or a part number for the pulley itself.
Thanks a mil.
Thierry
Hey everyone, so my ac doesn’t seem the coldest anymore, a little bit of a back story, it was a shuttle and it’s had the lot ripped out including the rear hvac (this maybe from there) had it degassed etc, but today I found this in the shed.
Now the van has been apart for a while now for...
Having owned my Caravelle for four years I've been trying to work out the heating controls for the rear passenger area and have come to the conclusion something isn't quite right. The first problem is that even when the correct button is selected in the overhead panel (shown in the image) for...
