air suspension
  1. L
    Show us your lowered van on OEM wheels
    Vans are expensive, and Van parts are expensive. I’m about to lower my van, but I don’t have money for wheels until July/August, so I was wondering if anyone has any pictures of their van lowered on OEM wheels? I think I might even keep the Clayton’s as winter wheels, to save my future 20’s...
  2. willgr
    Air Suspension for inflating tyres?
    Does anyone has any experience of using the tank drain valve in their air suspension set-up for other purposes? I’m wondering whether - with a suitable valve and gauge - I could use the air tank as a source for inflating bike tyres, or maybe even van tyres in an emergency? It seems silly to...
  3. willgr
    Airlift 3P Fault
    I’ve been running Airlift 3P with twin SoLow SHHH compressors without any issue for just under 2 years, and then last week it completely stopped working - it’s as if the manifold and controller are without power. Fortunately the van is at ride height (and stuck there) but it makes me nervous...
  4. J
    Winter mode: raising suspension for the season
    So I'm not quite done with my 20s, I still love the look. So my plan is to run the 20s in summer and 17s with AT tyres in winter. I'm currently dropped 40mm on springs. Is there an easy way to switch between 40mm drop and standard height? I'd like to run at standard height when in "winter mode"...
  5. goldeneye243
    Solow Air+ Suspension
    Does anyone have any feedback on the Air+ Suspension? It looks like a good fit for what I want but it is new to the market, so I am wondering if anyone has had it fitted yet?
  6. The Van Cave
    Sold SoLow Air Suspension - T30, T28, T26. Low mileage used kit. £1500
    I've just removed this kit from a customer van to replace it with a full swamper lift air kit from ABP. It was originally supplied and fitted at the cave 12 months ago and has been driven approximately 3000 miles. It's in excellent condition as can be seen in the photos and if you choose to...
  7. U
    Coils AND airbags?
    Has anyone successfully fitted airbags to a coil set-up? It looks like it might be possible with maxpeedingrods but not 100% sure. Having previously been a mechanic and later auto electrician, I have very little faith in a purely airbag system. When a coil spring breaks, you can generally still...
  8. Jake-755
    Engine Under Tray - Lowered Vans / Air
    Hey Folks, First time posting so play nicely ! I'm looking into the possibility installing an under tray to help with road noise, protecting the belts etc. My van (T6.1) is on air so wondered if this would cause any issues with clearances when airing out at all ? I'm assuming not but would...
  9. cgtmiles
    Ultimate campervan suspension?
    Thoughts?
  10. SirVelo75
    Sold 2017 SWB Kombi | T32 | 204ps | DSG | 4Motion | Air ride by Plush Automotive. £31,995 ono No VAT
    Ultimate spec T6/T32/204ps/DSG/4Motion - 2017 (66 Plate) SWB Factory Kombi (twin slider) 6 seater. - 2.0 bi-turbo Euro6 engine - 20” staggered wheels: 1AV ZX4 Satin black (9J front ET38 | 10.5J rear ET42) correctly load rated for T32 complete with VW centre caps. - Full set Pirelli P-Zero tyres...
  11. chrissielesmore
    Garage in Wiltshire to work on van with air ride
    Hi All, I’ve got a T6 fitted with Air Ride (originally done by Plush). Van has just been diagnosed with a bent drop link (which I have got a replacement of - as that’s what I thought it was) and a “shock that has gone through the top mount”. The garage it’s at won’t do the work on it, as it is...
  12. 5n0wb0mb3r
    SoLow Air Issue [Resolved]
    Hi guys, Have a small issue with my Solow Air. It's been installed for 4-5 months now, but went to go out in it today and and seem to have a leak at the rear somewhere. Wondering if anyone has similar issues or can diagnose. Annoyingly can't get a jack under to look. Videos here...
  13. Dai_namik
    Coilovers or air, T32 LWB
    Hi all, I have a 204 DSG 4Motion T32 LWB kombi, bigger factory brakes and factory arb's. It's normally empty apart from 5 seats and I drive it like I stole it. I've always planned to put it on air so I can air it out to look cool, and lift it up to stop me breaking splitters off road (4 in...
  14. T
    Modifying the vehicle gvw after adding vb air suspension
    I'm getting a camper on t6.1 chassis and have the choice to upgrade to 32t or 35t, each costs about €1000. I plan to add a vb 4c air suspension so i shouldn't need to upgrade, but wondered if anyone had had their gross vehicle weight officially changed on the vehicle registration after...
  15. The Van Cave
    SoLow Air Suspension Coming Soon to The Van Cave
    Hi All. This is a long post, but there's a lot to say! Solow Air Suspension will soon be available at The Van Cave. I will soon be installing one of the first available kits to my own demo van, with first customer installs following shortly afterwards. Kits are expected to land within the...
  16. p6raf
    AirRide presets
    Just had Air ride installed to simplify my sons wheelchair access and must say it's a game changer. No more heavy ramp sliding around in the van and far quicker to get him in. However, I've been playing around with the 3 preset pressure values. Mostly trying to find the lowest safe running...
  17. L
    VB air ride failure - what replacement?
    Hi , I mounted 3 years ago the VB air suspension, front and rear . Since then the VB dealer replaced 3 times the front suspensions because of a failure . The last time they've been replaced lasted until today when the front left started again to leak air . I decided to take it off and replace...
  18. J
    OEM+ Style Devonports
    Nearly MOT time and the 20" Calibre CCU's tyres I had on had some uneven wear, so had a look in the garage and saw the original Devonport wheels that came with the van back in 2018 and had a bit of a moment. Hmmmmmm, got some 25mm spacers for the rear and 15mm spacers for the front from Tamar...
  19. Eli
    Who’s got what suspension
    You may have something that isn’t listed so let me know and I will add it to the list
  20. G
    Sold Air ride
    Hi i have some air ride parts to sell, all 4 air bags plus the compressor. Been told they are worth £1000+ . Open to offers
