ambient lighting
  1. B
    OEM ambient light install
    I’m wondering if anyone has the destructions to install the oem ambient lighting kit? I’ve had a good search of the forum and seem to find a few kits that people have put together (and also gave me some great ideas to expand it with!) But none for the VW kit. Any help would be appreciated...
  2. S
    For Sale T6/T6.1 Two Colour LED footwell lights
    Hi folks Finally got around to build few of these for sale. Limited run of T6/T6.1 footwell light kits for sale. These lights stay on one colour of your choice while driving and switch into white once the door is open, van unlocked, key taken out of ignition etc. The kit is fully plug and play...
  3. R
    Combined courtesy and ambient lighting (white/red light)
    Thoughts please... I'd like courtesy AND ambient lighting that is white and red respectively. I figured I could modify these by replacing the switch function with a relay of some kind that switches between off/red/white...
  4. M
    Steps for steps light?
    Hello everybody, i have now looked thru most of the forum and can't seem to find anywhere which exact steps (part number) I need for retrofitting the steps light. I have already the lights but I can't find the correct steps. with the correct cutouts. Can anybody out here help with this one?
  5. DTT6
    Ambient lighting for passengers in the back
    I’ve read many posts about front door card LED’s but haven't found any ideas for my issue. I’ve a Caravelle and limo grade tints. Great in the sunny weather but really gloomy in the back for the passengers other times. It would be handy to have some decent door card type ambient LED’s instead...
  6. 360ian
    T6.1 Ambient lighting retrofits?
    Hi guys, Im finally a Transporter owner as of last week after wanting one since I was about 15! After picking up my 2021 plate T6.1 from Manchester last week, on the 200 mile drive back down to Somerset I noticed how dark it was in the cab compared to my other drive, an Audi A3. I have been...
  7. Pauly
    Adding footwell lighting
    I am in the process of adding footwell lights to my van and seems like its pretty easy to do, im looking at making up some plugs/cables to make it plug and play with no wire cutting/joining just factory connectors for everything. Wondering if this would interest anyone else as before i fit it to...
  8. F
    Heated-seat retrofit with illuminated buttons
    I have a T6.1 Van and fitting heated seats and to light up the switch when the lights are on I need to find a dash light wire. Can anyone tell me an easy dash light wire I can tap into? Also looking for a Ignition on Accessory wire to tap into.
  9. Texxaco
    Live headlight feed, where do I find it?
    I am looking to install an LED light to come on with my automatic headlights but not sure where I should get the feed for this. The LED light is 12V, can anyone help with the best solution? Thank you for any help offered.
  10. M
    Sold W8 Ambient Centre Light Free
    I bought this off eBay for £50 but didn’t fit it due to the marks etc as shown. It’s fully functional but it could do with a respray in my opinion. Free if anyone wants to cover the postage.
  11. K
    My install: Ambient footwell LED lights install using OEM connector
    I had a go at installing the travelinlite 3 colour led footwell courtesy lights today as ambient lighting instead so connected to the illumination dial. I wasn’t keen on using the posi taps supplied with the kit or splicing and wanted to try and keep it as oem as possible and removable without...
  12. dennismo
    Internal LED Touch Lights - Warm White
    Looking to source 8 x LED Touch lights in warm white. However, I'm struggling to find some that default to ON. I.e. I want to be able to wire them so that they come on when doors open / can be turned on with a switch, but then can be touched individually to turn off. I'm pretty confident they...
  13. Andysmee
    Ambient lighting - adding to door cards and lower dash
    Again, not a fully fledged [GUIDE] as there are lots of ways to personalise this, but here's the steps. In the doors you can tap off the window switch backlighting (above) and in the lower dash you can tap off the dashboard backlight dimming switch or the headlight switch (below) and any...
  14. Daddio3750
    Step lights - Change from Courtesy to Ambient?
    Hi All, calling all electrical geniuses! Does anyone know if it is possible to change the step lights from a courtesy function into an ambient light function (ie fitted with blue LED replacement bulbs and on when the dash lights are on and not just when the doors are open. If you do know -...
  15. Theo1979!
    Mirror ambient light
    Yesterday a installed ambient light in the mirrors
  16. Andysmee
    Team Ambient (put that light out, I'm driving)
    As winter's hitting and the nights are drawing in, it's a good time to get sorting the ambient lighting in the van. There's loads of threads on how, so no need for more guides, but how about showing us what you got? Trying to capture the effect is difficult too. HINT: if it's visible in...
  17. Shaggy1969
    Ambient lighting LEDs too bright
    I’ve fitted white LEDs to both the door lock handle and pull handles but they are a bit too bright. Any ideas how to dim them down a bit? Perhaps an additional resistor or something?
  18. Skyliner33
    Adding ambient/courtesy lights.
    I am planning on adding some ambient and courtesy lights. This is what I want to add at the moment. 2 courtesy step lights for the front doors. 2 courtesy lights in the front front footwells. 2 ambient lights in the front footwells. 2 ambient lights on the rear of the front 2 seat bases. I am...
  19. j4ckal
    Ambient lighting feed from headlight switch, grey/blue wire?
    Without a wiring diagram to hand, which grey/blue wire do I connect to for ambient light feed. The slightly larger grey/light blue (left of plug) or the thinner grey/dark blue (middle of plug)?
  20. Sabre
    door card LED
    Just been looking throught the other threads on this as I have put my own 'downlighter LEDs' into the door pockets, (only one small faux-pas with passenger side being too close to the back wall, but thats manageable) but, also drilled the back of the door handle in the centre to fit a LED in...
