anti-roll bar
  1. CKZ 102
    T28 to T32 Arb Upgrade Questions
    Evening. I’ve just purchased a pair of T32 Arbs to upgrade my T28. The ARBs have not come with Bushes, Clamps or Bolts. Questions. - Should I Polybush the ARBs or go for standard bushes? - Can I reuse my T28 clamps and bolts? Cheers
  2. F
    For Sale T32 Front and Rear ARBs
    Only bought these a week or so ago. Change of plan as I’ve gone H&R. Bushes in good condition etc Collection only from Eccles (Manchester). £70 (what I paid for them - for quick sale)
  3. Adever121
    For Sale T32 anti roll bar front
    T5.1 T32 front anti roll bar £40
  4. M
    Sold T32 Anti roll bars
    T6 T32 front and rear standard ARBs. Upgrade for T28/T30 £50 ono Collection from Stourbridge, west Midlands but could potentially arrange delivery at your cost if needed.
  5. danncus
    For Sale 2018 T6 T32 front and rear Anti Roll Bars ARB
    Good condition with bushes. Great upgrade for T28 T30 etc Collection from SK9 Handforth (5 Mins from Manchester Airport) £80 ono
  6. Y
    For Sale T30 Front and Rear Anti-Roll Bars (T6.1 2022)
    Looking to stiffen up your T26, T28 Front and rear anti-roll bars with fixings Taken off my 2022 T6.1 T30 £50each or £80 for both - collection from Chorley
  7. T6_MOF
    Found REAR ANTI ROLL BAR OUTER CLAMP 7H0511418
    Hi, As title suggest i’m after a rear anti roll bar outer clamp 7H0511418. Just checking here first if anyone can help, can seem to only buy online from Europe with 7day lead times and mines currently hanging off! Cheers.
  8. K
    For Sale T6 T32 Rear Anti Roll bar
    I have a T6 T32 rear anti roll bar available for sale, good upgrade for t28/t30. Available for collection in BD10 - £40
  9. T12
    Pulling to right after gearbox removed. (Hopefully solved, or not...)
    Hello, I am searching for help here because we have a very mysterious pulling to the right. At front the car have all new bunches expect subframe, but the subframe bolts are changed. All springs and dampers are almost new. Inner and outer tie rod are changed. The pulling problem came after...
  10. chappers0987
    For Sale T32 T6.1 4Motion Anti Roll Bars
    Front and rear anti roll bars taken off my T6.1 T32 4Motion. Covered approx 11k from new. Collection only from NG17. My van has factory led headlights, I’m told this may make a difference on the rear anti roll bar for mounting of a sensor. After £100
  11. JB_T5.1
    For Sale T32 Anti Roll Bars
    Front and rear anti roll bars taken off a 2015 T5.1 T32 but will fit T6. A bit dirty but good solid condition. Popular cheap upgrade to T26, T28 and T30 which come with thinner arbs as standard. £80 collected from Leeds LS28 or buyer can arrange courier as are in a box.
  12. P
    Sold T32 springs and anti roll bars
    Free to a good home. Must be collected from Worthing. Came off my 2020 T6.1 with 30k on it at the time.
  13. R
    ANTI-ROLLBAR LINK (ALL METAL) T6.1
    Hi folks, I'm after all metal anti-rollbar links for my T6.1. Can anyone recommend, please? I was told that Lemforder were good but it's not something I have any experience with. Thankies in advance :)
  14. P
    T5.1 / T6 / T6.1 anti-roll bars
    Going to upgrade antiroll bars. First are both t6.1 what's difference with t6.1 led and none led roll bars will both fit as I don't have led Second my rear anti roll bar is a std t5 one. Any differences from t5 to t6.1 on rear axle fitment and does lwb make any difference? Tempted on...
  15. smudger28
    Upgrading Suspension under £1000
    Hi I’m looking to upgrade my T6 18 plate Kombi’s suspension as the ride is somewhat wobbly if that makes sense. I’m not a mechanic so any advice is greatly appreciated. I’m thinking it could be lowered too. I’ve got around £700 to play with. Thank you ☺️
  16. Voodoo Developments
    Headlight Range Control issue since replacing ARBs
    I have a fault with headlight range control showing “Rear Left headlight sensor short circuit to b+ / open circuit” Slightly baffled as the sensor is on the OSR arm. I have changed ARB front and back, did rear first, no problem, then did front next day and it’s flagged the fault. I scanned...
  17. O
    H&R front anti roll bar install query
    Wonder if someone can help with this. I’ve got limited time this weekend to install the h@r front anti roll bar and I’m looking for any advice/tips to make it go smoothly. I’ve looked today while I did the rear which was a doddle but the front looks quite tight to get the roll bar out and the...
  18. M
    T32 Anti roll bar for my T28?
    I have a t6 t28 but a want to fit t32 anti roll bars would this make a a difference or should I get a h&r anti roll bars has any one got a old set of t32 arb for sale
  19. P
    Sold T32 springs and rear anti roll bar
    T32 front and rear springs and rear anti roll bar. Came off my 2020 T32. May be of use to someone locally looking to stiffen up the ride. Please check which other models they will fit. £50 the lot. Collection only from Worthing area. Can meet nearby if needed.
  20. RattyMcClelland
    H&R rear roll bar bushes
    Does anyone know the size or part numbers of the 30mm bushes on the rear H&R roll bar. My brackets bolt snapped, came loose, the bush has fallen out and is lost. It looks like I have to buy a complete roll bar kit just to replace the bush. H&R have yet to get back to me and no Transporter...
