auxiliary heater
  1. Lanky
    Sold Rear Auxiliary Heater
    Hi, I have this rear auxiliary heater that I took out of a brand new van when I converted it to a camper. It has to be worth £20. Collection from Edenbridge, Kent PM me if you want it.
  2. D
    How to control rear/roof heater?
    My kombi is factory fitted with a rear heater and 2 way ducting (roof and rear). The controls only allow me to set the temp and fan speed. I can see the servo in the heater but how do I get it to switch between the rear and roof vents? Its currently fixed/set to rear.
  3. Jeffers316
    For Sale Rear air con/heater from 2017 T6 Shuttle
    Clearing out my garage and have the following items for sale 1- Rear aircon/heater unit taken from my 2017 T6 when it was converted to a camper at 35,000 miles. Looking for offers around £60 2 - VW T6 DAB radio/disc/satnav unit-removed from 2017. Shuttle when I upgraded 18 months ago (was...
  4. M
    Auxiliary heater locked - Caravelle T6
    I guys, I got yesterday the Carista OBD, when I tried it I got some errors, don't want to talk about all of them now to avoid confusion, those I'm trying to sort out now are about the Auxiliary Heating: 0002 - No Flame Detected After Repeated Start Attempts 0056 - No Flame Detected During...
  5. B
    Rear aircon and poptop?
    So the van build planning took a break for a while but back on it, currently pondering the idea of if I find a decent kombi van with rear ac vents how difficult is it to reroute ducting and wiring once pop top is fitted, similar to that of a cali, I'm stuck on wanting a lwb or I think I probably...
  6. L
    Coding auxilery heater
    Hello, with ross-tech I changed the coding on my aux heater but cant remember what it was before i changed it. It was 4xxx. I have webasto and Eber. Multivan 2016 204hk Can someone with the same car give me the coding?
  7. Sturge
    Sold 2017 T32 SWB 204PS DSG 4Motion 7 seater Highline Day-Van, high spec. £29k
    ** Price reduced to £29k ** I have finally come to the sad decision to sell my van. I bought it new in December 2017, and so it is one owner from new. I ticked nearly every box when I ordered it, so it is very high spec. Still under extended warranty with VW for another 12 months (service...
  8. C
    Using rear compartment heater to create clothes drying box
    Maybe this is a totally crazy idea, but as the van I have has a rear compartment heater, I was thinking about building a box around it to use the warm air to dry clothes (e.g. wetsuits). Obviously a suitable exhaust would need to be found, and no doubt plenty of other things to think about, but...
  9. P
    For Sale VW T6 rear heater
    I have removed the rear heater and panel from my T6. They are both available if anyone needs either.
  10. T
    T6.1 Aux heater problem
    When I try and start my heater the screen lights up and displays “aux heater off’ before going off again, same with local button or remote fob. Previously I received message that that battery was too low, but since then I have charged the battery back to full. Since then I have tried to operate...
  11. 3crispies
    Rear interior panel part no
    Looking for part number so can add one to passenger side. Sorry hoping not to remove to check on rear of panel. Thanks in advance
  12. M
    Can you fix rear seatbelt with rear heater?
    I am looking to purchase a T6.1. I haven’t yet been to see it in person yet (hopefully next week I’ll get around to it), but would need to fit a 2+1 seat arrangement in the rear, a non-original Kombi so to speak. It’s a SWB, and has had a factory fitted heater installed in the rear. The floor is...
  13. GingerPig
    For Sale Rear HVAC unit / heater / aircon from caravelle executive
    Rear HVAC aircon unit removed from Caravelle Executive All in good working order before being removed £50
  14. R
    aux heating and bulkhead
    Hello All I've got the optional heating in rear (Kombi) now we have fitted the bulkhead the air blower is behind the bulkhead and useless, is there an adaptor or hose etc of do i need to cut a big hole in the bulkhead? Thanks Ray
  15. M
    Shuttle - recommend fans?
    Dear all, my 9 seater van has only front air-condition. :( during hot days, like these, it is very difficult to cool back seats and my kids feel very very hot. :eek: I have an idea to mount two roof or side fans just to push the colder air to the back. Red or green position? Can anyone suggest...
  16. Samro
    Need help identifying code meaning [Resolved].
    After way too long fannying about with checking fuses, I wondered if anyone could help me identify fault 460035, which I believe relates to me inoperative rear heater on my T6.1 Anyone able to shed any light in what I should do next?
  17. Samro
    Help- T6.1 Rear heater control panel is dead?
    I noticed yesterday that my rear heater controller is dead. (Completely blank with no function.) A bit of research led me to check fuse 11 as shown in the below screenshot from the downloaded info from the forum: I have checked and tested fuse 12 and all ok. I appear to be missing fuse 11...
  18. P
    Factory Diesel heater turns off early.
    Hi, we have a brand new T6.1 campervan with a VW factory fitted auxiliary diesel heater. We went on our first trip overnight last week and were using the heater for about 1.5 hours during the evening (on a low setting) and then during the night we woke up cold so turned it on. It stayed on for...
  19. Steved55
    Retain rear-heater in Shuttle-based Camper?
    Having completed the wheelchair access removal we are now moving on to the camper conversion. I have read numerous posts on shuttle conversions, but can't convince myself on the usefulness of retaining the rear hvac unit. We will fit a separate diesel night heater as part of the conversion, and...
  20. copperdragon5
    T6 Beach Auxiliary Heater Problem
    Hello, I have a T6 Beach with Auxiliary Heating/Parking Heater, but it is not turning on. The fault I'm getting from Car Scanner is: ============3============== 1207 Raw code: 04B7 ECU: 6E. Control Head Roof (VW TP2.0) Status: Test is inhibited by other DTC, Validated and stored in non...
