battery coding
  1. P
    New starter battery coding help
    Hi all. I require a new starter battery and I’ve read the thead on upgrading which I’m thinking of doing. If I do go down that route is the someone that can code it in local to me Dn14 area. 5 mins from jct 34 off the M62 for beer money. Or can I do it myself? Alternatively if I go with a...
  2. R
    Electrical issues.
    Hi Everyone, I didn't start my T6 for around 3 weeks over Christmas and the battery seemed to die. Was getting about 11.8v and was told I needed a new battery. So I bought one and things seemed ok for about 6 weeks. Then when I started the van I'd get random faults flash up. Start-stop fault...
  3. Sprengarfjord
    Battery coding
    Do i need to program anything to change battery in T6.1 2020? The battery is 3 years old and lose the power pretty fast, almost down to 11,9V So i need to change the battery to something better.
  4. S
    How do I get rid of my factory fit leisure battery? - Crafter
    Does anyone know how I can get this system removed so I can install my own? Tried VW main dealer as well as several recommended auto electricians local. Very frustrating!
  5. S
    Can Carista code in a new battery?
    Hi all, I need to swap my battery and register it. I have carista pro subscription so should work, but it doesn't come up in the service drop down menu which is where it should be. When I interrogate the vehicle supported tab, my t6 says battery registration is supported, I have emailed...
  6. K
    T6 low battery after only a couple of days
    Hi, I've been having various problems with my starter battery over the past year and am not sure what to do next. The 2016 van was converted and a VSR was installed by the chap who did the conversion, which I've come to realise isn't suitable for a van with a Euro 6 engine. I replaced the...
  7. K
    Replacing LB Battery - what Ah & spec AGM?
    Just had my claim for a new starter battery (AGM) turned down because the parasitic voltage was excessive and is caused by the installation of a leisure battery. This was before I told them that the fuse to the leisure battery was removed but they stuck to their story and wanted to charge £115...
  8. Grim Reaper
    Upgrading Starter Battery - how to guide
    My van (April 2017 T28) is fitted with a Moll battery. I am experiencing some issues with it not starting after a few days sitting on the drive. Now this could be due to the tracker I have fitted draining it but I doubt it, I'll do some drain current tests before taking the plunge. If I were to...
