battery drain
  1. K
    Is my starter battery knackered?
    Hi all- I've had issues (and am still having) with battery drain on my 2021 T6.1 Transporter. I was trying to work out if there was a drain from the tracker & alarm but I also suspect the battery might just be dead and need replacing. I'm after some sage advice from the forum to help!! I'm...
  2. revdecal
    Advice for battery life when your van is not used
    I have just bought a daily driver so my van will not be used so heavily. I will be parking it at my business but it will not be near any power source for a trickle charger. For some reason the battery goes flat after a few days. Any advice for battery life when your van is not used as regular? I...
  3. S
    T6.1 Battery Discharge
    Good Morning, yesterday I was working in the back of my van sound deadening the sliders, it is a T6.1 T32 2022, and I switched off the courtesy lights and the key was not in the ignition. I was opening/closing the sliders and had the tailgate open and was probably working in the back for about 3...
  4. tinctina
    T6.1 Low battery after 3 weeks
    Hi after 3 weeks not running my t6.1 says low battery is this normal Thanks
  5. R
    Leisure battery drain
    What's going on here then? My set up is a 100ah SLA battery, charged by a VSR when on the move. Connected to it is a PMS3H which handles all of the mains etc. everything goes through a Victron Smart shunt with a temp sensor for the battery. Also have a Victron 75/15MPPT connected which...
  6. GSX1400k3
    Starter battery still charging after 14 hours whilst static
    Good morning and go easy as I don't understand electrickery. Background, I work away and live in my T6.1 for up to 4-weeks at a time with no EHU. Mods, a second leisure battery, inverter for the Microwave, Orion smart charger and solar. Issues, 1. Starter battery drain, now on third battery...
  7. S
    Battery drain or dodgy battery?
    Hello hope you are all well. I have a 2021 T6.1. Every now and again in the morning it would struggle turning over, but would always start. When this happened the dash always showed "VCC error", along with some other errors (I cant recall right now, but I think it said the senser that the...
  8. W
    Leisure battery unknown drain
    Hi, really needing some help with my new camper. I recently bought a T6 all kitted out. Everything seemed to work ok to begin with in the first month. I took it away on a weekend trip and noticed the battery was not charged so I had to go to a site and hook up to get electricity. After leaving...
  9. CrazyDunk
    Solar Install & Mystery Vehicle Battery Drain
    Firstly, my set up: 90ah agm leisure battery CTEK dc to dc charger Victron Ac charger T6 2019 Highline camper conversion with low mileage of 15k on the clock Job last week carried out by professional installer: Upgraded agm leisure battery, now 130ah Installed solar and connected to CTEK Tidied...
  10. Iany1954
    Permanent battery charger leading to Quiescent Current error code
    Several days ago I fitted a permanent battery charger connection to the starter battery (directly across the terminals). I now have a CTEK MXS5.0 connected permanently while parked up at home. This keeps the starter battery fully charged and as it’s ’intelligent’ should not cause battery...
  11. revdecal
    Advice - charging battery when not in use.
    Looking at buying a 2nd vehicle so my T6 will not necessarily be my daily driver. I will probably keep it at work but it won't be near a power supply to keep the battery topped up. Any ideas on the best way to keep it charged or isolate the battery so it won't de charge when not in use? cheers
  12. D
    Leisure battery expected drain
    Evening all, hope those that can are taking advantage of the fine camper weather ☀️ I've just installed 2 x 120ah AGM Advance leisure batteries in my camper. I also bought a quicklynks BM2 monitor to help keep an eye on their health. When I first installed the batteries they were showing a...
  13. F
    I wish to keep the slider open without flattening battery
    Planning our first camping trip this weekend would like to keep the side door open, noticed the display light in instrument cluster stays on when side doors is open. Any way i can turn it off i fear other systems could be running. Thanks
  14. Y
    Start Battery Drain - Sorry yet Another Thread.
    Having read many threads on here, none seem to replicate my current issue. Having checked the drain on the battery with the multi-meter I am seeing a 1.2amp reading. If I remove the radio 30amp fuse this drops to 0.17amps. To further complicate the matter, I have recently noticed that if I...
  15. Hamster67
    Low Voltage Battery/ errors.
    A month ago my van was struggling to start, I tested the battery and it did indeed need replaced. Since that time I have been getting random errors, coolant temp sensors, camshaft pos sensor. I have replaced the battery and the 3 sensors, reset the faults via carista but they returned. I...
  16. nikster
    Battery drain
    Our 2017 204 T6 Caravelle has battery drain issues, it’s been in the garage for a week with various tests and components removed/replaced to find the source but they have given up and said I need to find an electrician that specialises in such things. They thought they had slowed the drain by...
  17. C
    Parasitic draw from AdBlue heater
    Hi everyone, I have a parasitic draw on my T6 battery. Now found the fuse causing the draw c43 looking to be the ad blue heater? Can anyone help with this? Since I unplugged this fuse the draw on the battery has completely gone down. Any advice would be great please. Thank you
  18. D
    Battery drain (sorry, another thread)
    Hello I have browsed through other threads on the same theme, but looking for help with battery drain. When I picked the van up 1 month ago, the battery was flat. Jump started and it has been 'fine' since (although I was driving along one dat and noticed the red battery light on the dash). Last...
  19. Glennpea123
    Flat Vehicle battery [Resolved]
    Transporter T6 Hi all, my battery has gone flat again. It was new a few weeks ago because old one was old and kept going flat, now this new one has. Put on charge this morning and alarm came on and i couldn't turn it off..eventually stopped. Am i doing something wrong with how I leave the PMS...
  20. D
    Leisure battery issue
    Hi, brand new to this forum and also a brand new owner of a 2020 T6, converted by Leighton Vans. I bought this van for work purposes, a couple of weeks ago I lived out of my van for 7 days straight with no issues at all, I did not plug into mains as I have a solar panel and that seemed to be all...
