Hi looking for help if possible, had the Blam amp fitted to my 2011 transporter but removed prior to selling as it a top quality amp. I’ve now got a new 2021 Transporter but the Quadlock is different but I still want to fit this is possible. Tried the original supplier but got no response. Does...
Originally supplied and fitted by Slidepods.
Compact amplifier - this was fitted up behind my passenger glovebox using some strong double sided adhesive, so very easy to accommodate.
Collection from GL51 preferred.
£155
Originally supplied and fitted to my van by Slidepods.
These were mounted in the rear of my van using the panels I am also selling on here.
Collection preferred from GL51 area.
£85
Removed from my T6 when I fitted the Absolut5 set up. Supplied and originally fitted by Slidepods.
The bass/mid units are a direct fit into the T6 doors using the included MDF collars.
Tweeters are fitted to grey A pillar trims. The pillar trims also have press studs fitted for a black...
We have been manufacturing underseat enclosure for Transporters for years, based on a JL Audio 10" sub
We are also about to do a active one
Many on here are running one...
I have Blam RS200 speakers fitted in the front, I now need to get some speakers for the rear planning on fitting them just behind the C piller near the roof I have ran the wires in so just need the speakers and mounting rings I have been looking at Blam 165RX (please bear in mind I...
Hey guys,
So would like a bit more from the vans sound system. Mine is a 2016 Kombi with the standard satnav headunit. I want to keep this as it does what I want but I would like a little bit more sound quality. Without spending £££’s is there a route that people have done? I’ve been keeping an...
Looking at swapping front speakers. Without stripping door first does anyone know what sizes I need to be looking at? Also any recommendations? Ta peeps
Audio upgrade Stage-1 . . . . BLAM Relax 200RS speakers from Skipton.
As the title says, so i thought i would bring you along for the ride . . . . . . . . .
stage 1 was to sound deaden the doors and door cards and fit the new 8" speakers and tweeters.
stage2 will be fitting the amps and sub ...
Having bough a new Kombi highline and had it converted to a camper we picked it up two weeks ago and are loving it. 1800 miles in and the music could do with a boost. Blam speakers and door sound deadening were fitted on the suggestion of the converter and from what I read they are pretty...
