bump stop
  1. 6
    Solow NSL. Bump stop
    Just fitted Solow NSL on my T6 t32. I’ve got the fronts about 15mm from max low . Ride height is perfect but the bump stops are sitting against the shock and the strut top with no gap for travel. Do you need to trim them ?
  2. T
    Clonk / bang over bumps - coilovers
    Hi guys, So since fitting the coilovers (twin adjust project low), I have discovered a bit of a ‘bang’ at the back when going over a harsh bump quickly. Although not a major issue (most roads, bumps etc are fine) I still want to solve it. I ‘think’ its the collars if I am honest. I removed the...
  3. JimbobT6
    B14 shock bump stop & dust cover?
    Hi all, Newbie to the T6 forum. I think I know what the consensus will be but I thought I’d ask opinion anyway…. I just had a dedicated Transporter / custom garage fit some B14 coilovers up front (I managed to do the rear on the drive, but I gave up on the front after swearing for approx...
  4. djg87
    Rear bump stops
    Hi guys, Have just fitted solows and after shortening the rear bump stops a little one of the rubbers keeps falling out and the metal bit that’s above it inside the tube has come away to. Not sure why as I cut them both the same length and the other side is fine. Any suggestions as to how I...
  5. Bryn23
    Broken rear bump stop mount
    So I’ve just git a little issue to sort :mad:, just got back from a 2 month adventure and i found an issue, after I removed all the wheels, wheel arch liners and all the bottom trays to start removing all the red dust. I noticed my bump stop sitting at the bottom of the spring, and it appears...
  6. Paynewright
    Front-end Knock [Resolved]
    I've always had an occasional knock from the front when hitting a speed bump or pothole, from either side, which has got more frequent of late. Occasionally, the knock is a fair bit louder and can be felt through the floor via my feet. I recently put the winter wheels and tyres on and there was...
