c-rail
  1. B
    For Sale Roof Rails (Retrofit) & Bars.....also C Channel rails...
    Hi All - More Bits for sale from our poptop conversion (T6.1 SWB)- roof rails & (unused) cross bars. with bolts & caps.....also deep channel C rails for Left & Right - (from twin slider!) Make your best offer!.....collect from GL5 Stroud - Thanks
  2. R
    Question about adding an awning rail to a van with a low profile pop top..
    Hi, Has anyone fitted an awning rail to a van with a low profile pop top? I’m looking at something like the stitches and steel universal c shape rail, to go under the roof (I have a stealth B2). Will there be space or will it imped the roof closing securely? Is there an alternative? Thanks...
  3. G
    Van-X awning rail
    Hi to everyone. I'm a 2015 T6 SWB owner. Help... the van x rail. It comes unbent and I wanted to avoid drilling into the roof bodywork, especially because there is wiring there. The rail was a bugger to bend and adhesive went everywhere. That said, It works perfectly. I wish they'd provide...
  4. M
    C-Rail fitting with Roof Bars
    Hi All, I've just purchased a T26 with a camper conversion, it has the rails for a drive away awning, will roof rails fit over the drive away rails?
  5. Badjamin
    Found 2.4m C-channel Rail
    Hi Anyone near yorkshire got a surplus C-rail? (Edit) it needs to be roof rack compatible Can collect if the price is right. Cheers Ben
  6. Gunship
    Awning without an awning rail (suction cups & a tarp?)
    I want an awning, but I don't want an awning rail - even the little low profile one. Does anyone have an awning solution that perhaps uses suction cups or a magnetic connection to the van?
  7. Skyliner33
    Sold Camper Essentials Aluminium Bolt On Hidden Awning Rail LWB
    Selling my https://camperessentials.co.uk/product/vw-t5-t6-bolt-on-awning-rail/ Still on the van at the moment but takes minutes to remove. Looking for £60 posted.
  8. Andysmee
    Sold Funky Leisure C-Channel Awning Rail for Roof Bars - Length:SWB - 2.4m
    Used VW T5/T6 Pre-Drilled C-Channel Awning Rail for Roof Bars - Length:SWB - 2.4m Length, Near-side:N/S - Left-Side Collection from Reading or we can meet or deliver locallly - M4 J12-J8/9, Bracknell/Sandhurst, M40 J4 High Wycombe M3 Basingstoke for beer tokens £50 ono The awning rail won't...
  9. GreenFish
    Stitches + Steel Tarp Awning connection
    Hello, We bought a Stitches + Steel Tarp Awning last year but cannot connect it directly to the C-channel awning rail on the van as this is 8mm diameter and the S+S tarp Kador is 8mm + fabric. Someone lent us a driveway awning kit (6mm-6mm Kador and Figure of 8) and this worked fine but I...
  10. chappers0987
    Sold SWB Awning C-Rail
    Awning 'C' rail, used with by Vango AirHub driveway tent Open to sensible offers. Selling due to sale of T6 SWB and purchase of T6.1 LWB. Rail only, i used the threaded fixings that come with the van to secure it in place. Collection only from NG17
  11. 3crispies
    Sold Kombi Bulkhead
    Motexion bulkhead. £150 Collect Cambs or collect dubs@castle (if prepaid) Funky leisure C channel awning rails, have one for both sides (driver side pre drilled for reversal) £40 Will have a passenger seat swivel but still fitted until weekend pretty sure its sportscraft £80...
  12. Ashok2429
    For Sale Camper Essentials Hidden C-Rail SWB Interchangeable
    Hi everyone, After getting my pop-top fitted the camper essentials rail I had won’t fit anymore, need to look at an alternative. It’s for a SWB and interchangeable so can be mounted on both sides. Only been on the van a couple of months. £50 ONO collection from SE London
  13. T6 owner
    Sold White Plastic Awning rail, to fit under OEM roof bars. £20 collection only.
    For Sale White Plastic Awning Rail, SWB. Fits under your OEM roof rails. Near side, holes and shape. 10 min easy fit, and no corrosion issues with it sat on your paintwork (it's a nylon plastic) in the roof gutter. Has been on my for just 3 months. Pop top fitted , so no longer needed...
  14. G
    Drive away awning connections
    Looking for advice on awning connections. Got a Kampa Motion Air, travel pod. I love it. Presently using the storm straps and a magnetic strip. However, contemplating fitting a c bar, I think that's what it is called. However, been told that it will spoil the look of the van. Also, any thoughts...
  15. Mike Dean
    Hidden awning rail under Pop-Top
    Hi All, Does anyone have a hidden awning rail, the channel type with their poptop? I don't want the eyesore on the exterior of the van. Thanks, Mike
  16. Skyliner33
    Found LWB hidden c rail awning rail.
    As the title suggests. Anyone wanting to sell one stuck in the garage?
  17. Patch
    Sold Awning C-Rail - SWB Aluminium pre-drilled for passenger side fitting
    For sale - Aluminium awning rail to fit SWB T6. (2.4m) I have pre-drilled this for use on passenger side. Easy to fit (if you have step ladder). Comes with stainless steel bolts and washers (re-use your pre-fitted VW rubber washers under the rail). The rail enables use of Sun shade or driveaway...
  18. S
    Sold Stitches and steel van awning rail
    I have a pre drilled Stitches and steel bolt it straight into the roof bar holes £10 including postage
  19. I
    Which option to attach a Drive-away Awning — C-rail or Fiamma awning rail?
    Looking for some advice - I’ve got a dual slider van with a Fiamma F40 awning on the driver side and I’ve just bought a Kela V drive-away awning. I’m wondering if it would be better to attach a c-rail to the passenger side of the van and use that to attach the Kela V or if it would be better to...
  20. vw-me
    Stitches and Steel Awning C-Rail
    Has anyone bought one of these rails ? Standard C-Section Awning Rail
