Can anyone give me an idea if replacing a cracked oil filter housing is a big job.
Based in Chester area if anyone has recon for a good garage that can do this.
Matt
Hi, having a big problem with my van.
Issue:
Limp mode, van will not go over 3000rpm.
At 3000 rpm engine raddles and shakes with diesel knocking & dies down to idle or shuts off, completely losing power.
Light Blue smoke from exhaust.
No fault codes
Starts up quick & nice idle.
Drives normal...
Hi, I've been to look at a 2016 140BHP Manual camper today. It's done 115K miles and 2 mots ago there was an advisory for an oil leak but not excessive. Owner said it was sorted when cambelt changed but looks like cambelt was done before the mot with the advisory.
I have had a look under front...
Help!!!
We are on a road trip from Devon to Nuremberg in Germany in our t6 2016 van and the coil light flashes on the dash.
The van is then under power like the turbo not working. If you switch ignition off the light goes off and the turbo works but slightly noisier or perhaps it is just us.
We...
Hey there!
OBD2 diagnostics report has flagged an issue on the CAN Gateway:
"01044 – Secondary air injection valve-N112 short circuit"
I've found some pictures of the valve on various VAG engines, so I know I'm looking for a box with a little vacuum hose going in and out.
But I can't find any...
T5.1 2.0 TDI 100k CAAB
We only use the van for trips, and I've noticed a tapping noise that's got gradually worse over the last few months.
On checking under the he bonnet to try and locate the sound I opened the oil cap, and it was immediately clearer/louder.
There also what looks like...
Hi all!
Does anyone know if the CAAB bosch pump is interchangable with the delphi CXGB high pressure pump?
CRCP4S1R3520
vs
HRP720
My transporter: -16 2.0 102 hp transporter euro 6 -CXGB
Many thanks!
Hello
Just came home from work and an Engine Oil Amber light has come up. I've checked the levels and for any leaks and all good.
I have how ever been on a new site and scrapped the bottom of the van a little, again checked and no damage or leaks?
Having read a little says to check oil...
What makes a CAAB engine more powerfull than a CAAA?
I'm in Australia. My CAAB 103kw engine broke its crank. It has been replaced with a long motor and some of the bits from a 75kw engined short wheel base T6. E.g. the turbo and inlet manifold complete. Its still my Intercooler, rad and ECU and...
T6 Service intervals & inspections , Flexible & Longlife :
Im just posting this here to make it easier to refer back to in future . . .
source: Volkswagen Flexible Service Regimes (Longlife) | Volkswagen...
