caac engine
  1. Dellmassive
    VW Transporter Engine codes (T5-T6.1)
    VW Transporter Engine codes (T5-T6.1) do we have a definitive list of engine codes? if not then lets get one sorted out. ill start the list, . . . and in info below and ill update the main list.
  2. V
    T6 engine swap
    I’m looking on buying a 2015 t6 which has a blown engine can I fit an engine from a 2012 caa code
  3. J
    140 Euro 5 Whistle noise.
    Hope I can get some help. I've got a euro 5 140bhp and tonight it's developed what sounds like a whistle from the engine under acceleration. I'm hoping it's not a turbo fault as we're going away in just under 3wks. The EGR was replaced a couple of months back and it's been fine until tonight...
  4. John A
    Tafmet simulator on 2.0 140 EU5 CAAC
    Afternoon, I've read about the Tafmet EGR simulators on this forum and think this is a good solution to just blanking/mapping/replacing the EGR. It seems that the majority of them are for the BiTDi engines and there is nothing directly listed for the EU5 140 engine. I wrote to Tafmet who said...
  5. P
    T6 caac engine pilot bearing
    Does the t6 caac engine have a pilot bearing for the gearbox
  6. D
    2014 T6 Engine code CAAB Swap for pd engine?
    Has anyone swapped/converted a CAAB engine for the stronger more reliable pd 130/150 engines? I'd like to maybe do this. Any help greatly appreciated
  7. T6 Pilot
    EGR Cooler with low flow - teardown
    Hi guys Had a few of these EGR low flow faults lately on different vehicles. On one vehicle i removed the cooler and tried to clean in but with no luck. The cooler is a bit different so I decided to have a look inside and discovered why you’re wasting your time trying to clean them out. There’s...
  8. Loz
    T6 CAAC CAAB CAAC CFCA Diesel Engine workshop manual Edition 02.2019
    VW workshop manual for the CAAC CAAB CAAC CFCA Diesel Engine Click the download button above to save this file locally.
  9. northanmonkey
    Where to get replacement injector pipes?
    Hello Guru’s Having just bought an early T6. And from what I’ve learnt so far. It has a euro 5 CAAC engine (it’s a 140hp) which was also used in the T5? Question is. I’ve scoured the tinterweb for replacement injector hp pipes ( mine are badly corroded) but I can’t find anyone listing them? GSF...
  10. C
    Alternator not working? [Resolved]
    Hi all Does anyone have a guide to for service mode so I can change my alternator I am getting a regulator code and the alternator is not Charging. I have fixed a broken yellow wire from the positive of the battery to the alternator but still not joy which I believe is part of the smart...
  11. R
    EU5 140 CAAC Engine Oil Change
    Hi guys. I brought a new LWB T6 in July 2019. It's done 30,000km. Dealer is virus closed. Brought oil and filter today. 2.0 diesel CAAC 103kw and 340nm. They sold me 7 litres of oil and a cartridge filter. Can you please give me instructions where oil filter is etc and other relevant details as...
  12. Dellmassive
    T6 Service Intervals & Inspection, Flexible & Longlife
    T6 Service intervals & inspections , Flexible & Longlife : Im just posting this here to make it easier to refer back to in future . . . source: Volkswagen Flexible Service Regimes (Longlife) | Volkswagen...
