Hi everyone,
I'm planning to monitor the status of my doors (locked/unlocked) and windows (open/closed) in my T6 when the car is turned off. My idea is to use an ESP32 microcontroller along with a CANbus or LINbus transceiver. However, I'm not sure if these specific messages are transmitted via...
Hi - I bought an Alpine halo 903d and included with it was the quad lock and can bus supposedly for a T6 here in France.
My question is the speed sensor wire and to some extent the connect2 interface plug, as there seems to be nothing that it actually connects too.
I searched the existing...
Hi, I've replaced my headlights for my T6 with these Transporter HQ ones. The dipped beam bulbs (H7) are LED and look/work great. However, the best bulbs available for the main beam (H1) as an upgrade when I bought the lights were Nightbreaker H1s. Although these are only used when I need to use...
Folks, anyone managed to locate another location to hook into the powertrain can-l & can-h instead of white plug on BCM?
Soldering to the orange/black & orange/brown twisted pair seems a nightmare in that location.
I see the main loom runs through bulkhead but hoping a location in the cab might...
Hello fellow T6 drivers!
I have try to do HBA retrofit but missing some coding because my car won't do anything automatic to high beams. I have a used mirror with HBA camera and correct wiring for it. I did add FLA ecu to gateway and it shows no faults and status is active but I cannot find...
VW Self Study Programme, Document 186 Intro into CAN BUS
The requirements relating to driving safety, driving comfort, exhaust emissions and fuel economy are are becoming ever more stringent.
This entails more intensive information exchange between control units.
A well-engineered solution is...
Can anyone comfirm if the ghost is spliced in to the canbus or just wrapped I’ve spliced in to the canbus cables for the rear packing sensors and it’s stopped working.
Hi Guys,
I was hoping you may be able to help.
I've got my hands on the parts to retrofit my 2015 T6 Caravelle with an OPS kit for front and rear parking sensors.
So far I have installed the front and rear sensors, run the loom from front and rear, attached both buzzers, connected the earth...
Circuit Diagrams for the Data Bus Network
Covers all wiring between control modules on the drivetrain CAN bus and convenience CAN bus, also includes LIN bus wiring
Please check the history/updates tab, first release is for early T6s manufactured from June 2015, second release is for later...
