caravelle step light
  1. DaveCrampton
    Wanted Caravelle step light cover
    Sadly my driver’s side step light plastic cover has come off and fallen out of the van. I don’t want a whole light unit at £££ so if anyone has a link for or name of the plastic cover which protects the front step light, and can help me I’d really appreciate it. Many thanks, Dave C
  2. C
    Sliding door step height
    Well my vanstyle raised step doesn’t seem to fit with my 12mm ply floor, the bottom section doesnt sit on the base metal... although the rear piece fits perfectly. Any ideas on which others I should be looking at that would fit? It’s for a pannel van, ply sitting on top of the metal ridges...
  3. Pedro20001
    Caravelle side step light connector- where can I get one?
    Hi all, I have got hold of a bulli step light, the same as the caravelle ones but the connection is a very small 2 pin one. Does anyone know where I can purchase one please? I will post a pic later, TIA
  4. M
    Conversion Plug Kombi-Caravelle step lights
    So after fitting my Caravelle steps I have realised my Kombi step light plugs don't fit. Does anyone know of a conversion plug or part numbers for a replacement plug I can fit in its place. Cheers
  5. P
    Sold Caravelle front step lights
    Just changed my Caravelle front step lights to the LED T6.1 ones. These will fit T5 to T6 with the larger connector. Condition is fair as have a few marks. Tested all bulbs and comes with spares £45 delivered
  6. AdL
    Wanted Caravelle foot light cover
    Just been informed there should be a cover on this light. If you have one (or the complete light) I would be grateful.
  7. A
    Sold T6 Caravelle steplights x4
    4x VW Caravelle Step lights - £100 Got very minor marks, but overall good condition and in working order. Removed from 2020 Caravelle Collection from Devizes, Wiltshire or can post at buyers expense.
  8. M
    Sliding Door Courtesy Light
    Hi Hoping someone can offer some advice here i recently went to change the sliding door footwell light on my T6.1 assuming it had blown however when i removed the light i discovered that there was no wiring attached to it so can only assume that this was something that the converters had...
  9. IrishT6
    Caravelle step
    Hi all, can I upgrade to caravelle steps from a Kombi? Is the flooring the same depth? OR can the Kombi step be modified to accept the caravelle type light
  10. TheKeymeister
    Footwell / step light - LED conversion
    This may well have been done before, so apologies, but thought I'd show how I eventually fitted LEDs in my step lights...it's pretty simple but I tried to do it in a way that I'll be able to finally forget about it without any worries, so thought I'd share :D Originally I bought a full...
  11. Trouts
    Sold OEM Kombi Step w/light
    as part of my ongoing efforts to tidy the garage, this is now for sale. not needed due to a conversion but in immaculate condition. looking for £50 plus postage please. or can meet locally (north) Manchester :thumbsup: *there's also potential to meet somewhere between Manchester and Reading...
  12. fezza68
    Wanted Step light covers
    Hi all, im looking for one or a pair of step light covers if anyones got any knocking about?.
  13. Phil Blackburn
    Caravelle LED step light with new plug
    Hi folks Received some new caravelle rear steps which have come with LED lights, problem is they are a different plug and socket arrangement to what I have on the Kombi and from all the other lights I have seen, does anyone know the correct part number for the plug to match the light which has a...
  14. M
    Drivers T6 door step with vent and Factory light cutout.
    Hoping somebody can help, I have been online for what seems like an eternity and cant find or establish what part number I need to order a new offside front drivers step with heater grill and factory light cutout in satin black 9B9 - 82V. Also need the part number for a new nearside front...
  15. Sam Lawson
    Caravelle Step Lights - cover only.
    I've seen this has been asked before, but nothing recently. I'm tidying up my Caravelle, and the plastic covers on the step lights are a bit scuffed or cracked. It seems you can only buy a full lamp unit rather than just the cover. Wondering if this is still the case? I'm sure someone with a 3D...
  16. Gareth1
    Caravelle Step-Light LED bulbs
    Hi Having recently converted my interior roof mounted lights to LED lamps, I'm now looking to swap my front driver and passenger step lamps also to LED. These are the ones that have 4 separate warm white lamps currently installed. Does anyone know the lamp type so I can order some replacement...
  17. L
    Caravelle front step light wiring/connectors
    Evening all, I’ve just picked up a cheap set of caravelle front steps for my Kombi. I’m looking for the part numbers for the connector plugs and pins in order to wire them to the courtesy light circuit. Thanks in advance :thumbsup:
  18. OllieGBR
    Caravelle Step Light power
    I've searched and I know from @Skyliner33 posts on his build that you need a Caravelle step to accommodate the additional height the floor brings. What I can't find is how this is wired in? Is this powered by your leisure battery or spliced from the door switch?
  19. Skyliner33
    Caravelle Step Height?
    Looking for some help. I’m thinking of putting a Caravelle step inside my drivers door step. I’m just wondering if it will be the correct height for my carpet.
  20. fezza68
    Caravelle Step Light Removal
    Looking for help on how to remove the front step light cover. Is it simply a case of a trim tool behind it?.
