carbon monoxide
  1. W
    Carbon monoxide detector recommendations
    Hi, can anyone recommend a carbon monoxide detector for a campervan? Don't want to wire it in so internal battery operated. Not sure on whether I want to screw it on or stick it on a surface. Don't want to spend the earth but must meet all relevant safety standards. TIA
  2. Vdubster
    Gas/Co2 Alarm active all the time? will it drain the battery?
    I have just installed a CBE LPG ad CO2 detector/alarm, for some reason i thought it might be battery powered but its 12v, would i be safe to assume this is to be on 24/7? and in turn will this not drain my battery or would the power consumption of it be to low for it to matter? i think its...
  3. S
    Carbon Monoxide Alarm
    Hi recently brought a 2017 T6 and the carbon monoxide alarm goes off, after taken everything out and put it back one by one it was OK until connected to mains hook up and it started again !!! any ideas or suggestions would be gratefully appreciated.
  4. T
    Smoke/CO monitor recommendations
    Hello, newbie here. We have just picked up our newly converted T6 and looking at smoke and carbon monoxide monitors. Does anyone have any recommendations? Is it better to go combined? And can we place it at the end of the long light/cupboard above the sink? thanks!
  5. D
    Carbon Monoxide False Alarm Problems!?
    Whilst sleeping in the van with my wife and 9month old baby daughter last night at about 4 or 5am the carbon monoxide alarm set off. We're in France so we weren't using the diesel heater and we hadn't used the gas hob that evening either. The only appliance running was the electric compressor...
  6. Oldrat
    Gas. On or off ?
    Reassurance needed please.:unsure: Our gas cylinder cupboard is accessed by opening the tailgate. We make sure that it is off most of the time, and only on when we want to use the cooker/hob. But after our first overnight test in the van, its aparent that getting out of the van to turn the...
