ceiling light
  1. Y
    VW Passat W8 overhead lighting module
    I've just bought one of these and the wiring loom. Before I fit it I would like to change the four bulbs to LEDs. Does anyone have any links to LED replacements for these bulbs? TIA
  2. C
    Daft question
    Hello, Prob daft question. One of pop top surround lights keep ‘popping out’. I have tried manipulating back up into what looks like plywood surround, feel like I am in danger of damaging wood. Anyone got any tips for a divvy? Many thanks. Chris
  3. E
    Interior map light control panel
    Hi all, the control panel with the map lights at the front of the van has the main switch broken off. The switch that you turn on so that when you open your van doors the light comes on. This means that when we open our van door the map light at the front of the van does not come on. I’ve looked...
  4. J
    Shuttle overhead light fixings
    while replacing the bulbs with LED's i damaged a few of the metal locating clips! Any suggestion where i could get some replacements?
  5. Zave
    Eyelets in ceiling for storing long items with bungees e.g. surf board
    Hope the thread title makes sense. I'm looking to install eyelets along the edges of the ceiling in order to bungee long items in place e.g. a surf board, thus leaving the floor area free. Does anybody have photo's they could share of this please.
  6. M
    Sold W8 Ambient Centre Light Free
    I bought this off eBay for £50 but didn’t fit it due to the marks etc as shown. It’s fully functional but it could do with a respray in my opinion. Free if anyone wants to cover the postage.
  7. T
    Upper cubby hole box removal...
    Hi All how do i remove the overhead tray just the inner tray bit (in red) from the overhead console? Does it just pry out with trim tools or is it more complex? thought id ask before starting to just pull it about Cheers Justin
  8. J
    Ceiling light changeout
    How easy is it to replace the rectangular lights with round led ones? Can I use the power in the roof on the old ones? Ideally I would like the lights to act as the existing ones, on with the doors and also switched on. Will the canbus bar me from doing this?
  9. Jlo
    T6.1 Removing the plastic 'cubby hole' trim?
    Before I go hacking at it, does anyone have any experience removing the plastic around the cab lights etc... Has it got a proper name? Thanks in advance!
  10. C
    My interior light has extra connections
    I have been trying to install a new W8 interior light, the one which illuminates the dash. Anyway, all was going fine until I removed the original light (this one has a fault on it). What I found when I removed it was a red & black cable cable soldered to either side of the interior bulb holder...
  11. S
    Travelin-Lite LED ceiling light help
    Hi guys, I have bought some LED ceiling lights from Travelin-lite. They all have a connector on the end but no female end for the connectors to go into. I want to connect them into the ceiling of my kombi, taking power from the factory ceiling light which is halogen, 3 wire type. How do I wire...
  12. Tsixty
    Front ceiling light removal
    OK newbie question of the day, how on earth do you get into this particular front light cluster to change the bulbs? There doesn't seem to be anywhere to get a trim tool in or anything
  13. D
    Interior light fuse
    Hi All I think I might have blown the interior light fuse. Does anyone know where it is?
  14. T6180
    Sold Passat W8 Ambient Centre Light
    As title, in grey/beige....whatever the standard colour is. Works perfectly fine all you will need is the connector and loom of fleebay, roughly £15 I'll post a picture tomorrow Looking for £35 plus postage
  15. S
    Overhead Console Clips
    Does anyone know where I can buy in the UK the metal spring clips that hold the overhead console in place. I have literally searched everywhere and the only place I can find them is in Europe and they want £50 postage for 10 small clips!!
  16. Vanbus
    Part Number - overhead console Cali
    Hi all, Im trying to find the part number for the small rectangle panel in the image but without the sun roof controller in, so just a plain panel. Its from a T5 Kombi, but also similar in shuttle. We have not got another van here with the same headlining to check. Thanks for your help. Cheers
  17. bullracing
    Interior Overhead Roof Console / Cubby Hole Swap
    I have a shuttle so seem to have the old style overhead thingy (I am sure there is a proper name), like this. Is it possible to change to the newer style? any benefits to changing to the newer style? I will be getting a pop top soon so might be a good opportunity to change if it is worth...
  18. andy greenwood
    Interior Light Stays On When The Sliding Door Is Open
    the interior light in the front cab stays on permanently if I have the sliding door open. Is this correct ? if i'm on a camp site for example and were relaxing with the sliding door open its annoying that the light stays on all the time. If I close the sliding door then the light goes off...
  19. Dellmassive
    Cab Ambient Lighting (factory Mod) - How I Done It -
    Cab Ambient Lighting (factory mod) - How I done it - The lower dash LED lighting had already been done before thanks to the forum shop & @Pauly , which can be seen here: . so i though i would give the OEM style RED LED ambient lighting a go . . . . There are a few threads on T6F...
  20. dubdub
    OMG At Last!! Ceiling light rattle sorted
    Hi all, Since getting my T6 2 years ago I've been driven mad by intermittent rattle, I've spent a lot of time, money and effort soundproofing which works great but the down side is you hear more internal noises and this one has driven me nutts! It was one of those ones that seem to come from...
