2018 - T6 Transporter (not under warranty) - Quite often when I unlock the vehicle using the remote fob the sliding door doesn't unlock and takes one or two additional presses before it unlocks and the handle then works to open the door. Any ideas/suggestions welcome.
Thank you.
I’ve recently bought a T6 2017 Startline conversion.
I can’t figure out the enigma of being able to lock the can from inside but disabling interior motion detector.
I’ve scrolled other posts and have exhausted the following options…
1. There is no switch to do this on B pillar.
2. The...
Hi everyone,
I’ve have a T6 Camperking conversion and have discovered an intermittent fault with the sliding door.
On some occasions (but mainly on cold / freezing mornings) I blip the key which turns the headlights on and opens all the doors apart from the sliding side door. Both the outside...
Sorry can't find this (common?) fault amongst previous threads.
Every now and again my central locking will lock all doors as expected when the vehicle goes over 3 mph(?) but clicks around for a few seconds.
Its as if it can't lock one door so keeps trying them all. I want to say its a faulty...
I have a T6 from 2018. It's not locking by use of the button on the drivers door, however it is unlocking by using the unlocking button over there. The doors are opening and closing by using the key fob. Checked the fuse (only one 5amp?) and all ok. What could be the problem?
Thanks!
After long search for a van I found one that ticked a lot of boxes but in the proces I didn’t see that the van has no central locking. So I have to unlock each door individually. I was not expecting that from a 2019 model. But since everything else was good I bought it anyway.
After...
I park my van tight against a fence and exit through the passenger door. Over the last 6/7 years in my T5 I’ve had the misfortune of having a flat battery. With the T5 I could unlock the tailgate and climb through and open the bonnet. With the T6 Kombi there’s not that option, and the passenger...
Hi, my sliding door has stopped locking from central locking remote. All the others door lock and I can manually lock it from the key. The door will however unlock from the central locking remote. Any ideas anyone? Thanks in advance for any advice!
I have electric sliding doors, both sides. I also have autolock over 20km/h active, so each time I drive they are locked. However I've noticed some time ago that left ones need to be unlocked twice to allow opening, while rest (front and right ones) are "ready to open" after one unlock. It...
Hi, as the title suggests I need some really simple step by step instructions on how to shorten the barn door exterior handle locking rod. I couldn’t open the back doors at all, from the inside or from the outside.
After a lot of head scratching and taking the internal panel off, I managed to...
Hi everyone,
I'm planning to monitor the status of my doors (locked/unlocked) and windows (open/closed) in my T6 when the car is turned off. My idea is to use an ESP32 microcontroller along with a CANbus or LINbus transceiver. However, I'm not sure if these specific messages are transmitted via...
Good afternoon all,
I am posting this issue to try and get some clarity on the next steps with my tailgate and central locking.
Concerning a 2018 T6 Panel van in the throws of a conversion, For the past 4-6 months, the central locking has not been working, and the tailgate electronic switch...
Hi folks I’ve had a look at a couple of threads but think my problem may be slightly different. Power closing tailgate seems to occasionally have a bit of a meltdown, basically the mechanism goes on and off multiple times unless I open it and slam it shut and even then it sometimes keeps going...
Hi All
My Central locking has stopped working - The Lights Flash alarm arms but none of the locks make a sound.
the ABS and TC lights are both on to
plugged in Carista and it has thrown up below falts and wondered if it could be connected
any help or advice would be great
12888 -...
A few weeks ago I closed my tailgate on a full boot which then jammed.
I couldn’t open the boot externally and managed to open it using the internal switch (T6 Combi). I noticed that a folded table was pressing against the area of the internal switch.
All seemed well until later I tried to...
Hi I've notice lot people have similar problem with central lock.
So I've too .
I've done scan:
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 P HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0424
Revision: BO034001 Serial number: 0673...
Hello, new member here. This is not the first post I intended...
I seem to have broken my central locking/alarm. I ran a cable behind the glove box this afternoon and suspect I may have dislodged something? Is that likely?
If I press the key fob to lock or unlock then the indicators flash as...
Hi - Nubiel looking for some expertise.
My T6 central locking was working fine with the remote, then the remote stopped unlocking/locking the van. The transmit light on the fob flashes when pressed & the red light at the lock button on the drivers door still flashes (I'm guessing this is the...
Hi Need some idears on why my internal door locking button is not locking all the doors?.The doors are all shut press the button and it keeps popping up !
Any idears would be great 2019 T6
