Hi everyone, I was planning on going to look at a t6 on Saturday, it is 4 hours from where I live so asked for a walk around video, when looking at the engine it looks like something is bubbling? Is this the intercooler? Is it a big problem? I don't want to do an 8 hour round trip for a lemon...
My t6 204 is slowly losing coolant (separate thread).
One of the symptoms is that about half a dozen times the starter motor has struggled to turn the engine over.
It turns over for a bit then freezes as if there isn’t enough power to turn the engine over.
But battery and starter are strong...
Good day,
I have been having issues with my T6 150hp loosing coolant, looks like charge air cooler is leaking, when I removed one of the black big air pipes in the bottom it was wet. My guess it is coolant and not oil, but hard to tell.
I could not find any reasonable price for the T6 charge...
This should help identify coolers fitted to different models.
Bi-TDI models CXEB etc.
Single turbo engines
Engine Oil Cooler
DSG Gear Oil Cooler
Heater Heat Exchanger
Rear Evaporator
MY18 T32 PV 204 DSG
204 engine top-end oil leak?
on a rummage around the engine bay the other day i saw this =[
the van has done 10K from new and is due its first oil service in 2k or so at the dealers.
there seems to be some oil under the charge cooler by the red boost hose, its very high...
