Hi everyone,
I recently did a full scan with obdeleven pro on our 2020 VW T6.1 Multivan and this error came up.
I tried to google the fault code, the error description etc. but so far no luck.
Also I not sure we even have child lock on this door (but I might be wrong, we bought this car...
The tailgate on my van recently stopped opening... was really annoying as could only open from the inside if I needed to. I accidently discovered that when I turned off the child-lock, miraculously the tailgate was working as it should.
So basicly the child-lock is locking the tailgate from...
At the summer camp after a good nights sleep we found we were locked in our van as the sliding door would not open so I had to open the passenger door and open from outside. When we got home I booked our van in with VW in Stoke on Trent under warranty as our van only has 1 month left.
Anyway I...
So cleaning van out for Castlerigg tomorrow and packing when I realised that the sliding door wasn’t opening from inside.. so stripped door down and removed window blind to find nothing wrong. I’d only knocked the child lock button on the drivers door and not realised!!!!!!
Anyone else got...
New to T6.1 kombi ownership (2nd hand) and a problem has arisen!
I’m getting an electronic child lock fault come up on the dash, as well as front windows not being able to open. Neither switches on either side are working to open window. As I if left mirrors rotated up, they are also not...
Hi All, does anyone know what this piece is on the tailgate of my new to me T6?
I can see from doing a google image search that there is usually a black cover over this, but hoped someone could advise what this is so I can get order the correct trim cover for it.
Thanks for any help provided!
Hi all, not long after I insulated my van last year, I had an issue with the internal door handle not operating the door yet the key and outside handle were fine. It turned out that I may have dislodged the connector onto the switch that the handle operates. Well its happenned again, so me...
Hope you can help me out.
T6.1 on a 70 plate.
I'm having an issue with the internal tailgate release button.
External the tailgate opens as normal with the handle issue is just when I pull the internal toggle button it doesn't open.
I've used previous threads to eliminate the motor ...
Hey fam, new member here. Apologies if this has been discussed before but I couldn’t find anything. Whenever I turn on the ignition I get the above message on the dash. Has is anyone else had this problem? I took it into the shop to get it looked at and believe it or not it was the one time it...
I am having a nightmare today with the sliding door on my T6.1. Please forgive me as I am a knob when it comes to mechanics.
It was fitted with a Loc8 table, but do not think that has caused the problem, but you never know.
So, as far as I remember, the sliding door opened from the inside (and...
Whilst sound deadening my tailgate I keep knocking this small latch off, looks like it can isolate the inner handle or something, it comes off really easily.
Is it missing a cover of some sort?
If so, does anybody know the part no for a new one?
it was like this when I got the van.
Hi all - anyone help me with a part number for the little oval shaped cover - I’m missing one to the right of the tailgate lock as in the picture. Not vital but bugs me every time I open it!
Thanks in advance
Anyone else had the child lock plastic fitting in the sliding door fall at their feet when the doors is opened?
Done it couple of times now. Seems like the plastic fitting is very loose in the hole provided in the door.
Just shoddy tolerances by the look of it.
Anyone else had the same problem...
