control panel
  1. roooms
    Any aftermarket cleverness with the Webasto parking heater control unit?
    I've just bought a new (ebay) centre control assembly that sits between the sun visors as I wanted to replace the gloss black one that cam with the van but I didn't like. It includes this control unit which seems to be for an OEM webasto heater. My existing setup has a dummy plate there, so I...
  2. JFWerkstatt
    VW Transporter heater issues, heater control panel, control cables. YouTube link inside
    Hi everyone. I’ve recently reignited my YouTube channel. Part of which is going to include some videos on some common issues. This is more suited to the non digital control panels however, gives a little insight into the system. Very unprofessional at the moment but with time they’ll get...
  3. ERICTHEVAN
    Sold Unused Electrics Kit incl Fuse Box, Contol Panel, 240V charger CBE PC210 Kit (less consumer unit)
    CBE PC210 Kit (less consumer unit) I purchased this kit from Kiravans back in March but, with the exception of the consumer unit which I have put in the van, I have not used/installed any of it. The pack is made up of the following: CBE DS300-UK - Fused Distribution Box CBE PC210-ST -...
  4. C
    Kiravans control panel
    Has any fitted one of the kiravans control panel is it any good I just need to run some lights and my slidepod https://www.kiravans.co.uk/products/kiravans-campervan-electric-12-volts-control-system
  5. H0ME
    Control panel voltmeter - LEDs
    Hi - I have installed one of the smaller control panels with an LED voltmeter. I assumed maybe incorrectly that it would go to sleep after a time? Is this not the case and this thing is permenantly on - so making light blue haze in the corner of the van through the night?! Not good.
  6. C
    Control Panel dead on T6 California Ocean
    Hi guys, went to pop in to my VW Cali T6 Ocean at the weekend after not using it for a while and found the central control panel for roof heating etc dead, backlight works when I press the one/off button goes off after 30 secs but nothing on the display at all, have checked 3 5 amp fuses 1...
