Yet another set of engine's built-in tests to try.
HOW-TO run engine's built-in test for EGR cooler pump
IGNition ON (engine not running)
VCDS > Select > Engine > Output test > IDE00879-EGR cooler pump
Select "Measuring Values"
Pick up e.g. the following data items for monitoring - the same...
I'm new to the forum. I have a 2021 shuttle which is showing an engine light. Code is p24ae which is the particulate matter sensor circuit according to my cheap reader. Is this something well known. Trying to save myself a day of hassle with the dealer in this but there is a warranty...
Hello,
Engine management light has popped on.
It's a Carista code 27616 and also a P190D code. Both of which point to something called the Intercooler Coolant Pump. Is the same thing as the Auxiliary Water Pump? I believe it's used to regulate heat and is not as critical as the main water...
Hi Guys
Still have a problem with the battery going flat over night. Its getting a bit embarrassing when I pull up to a job and flip the bonnet to disconnect the battery !!!
Anyway had a bit of spare time today and the drain is 0.3 amps, I have pulled some fuses to isolate the problem and if I...
