coolant sensor
  1. SlothBurger
    Coolant Temperature Sensor Not Getting To 90
    I've owned a couple of VW's and Audi's and they all got up to 90 degrees temperature and stay at that for the duration of journeys. On my 2019 T6.1 Kombi it never gets to 90 degrees but seems to fluctuate below it and takes a long time to get up even near 90 - usually staying at 70 degrees...
  2. T
    CXH engine coolant sensor
    Wondering if someone could help me out with a part number for the engine coolant sensor located underneath the intake manifold, replaced intake manifold and now have coolant flooding out of the sensor
  3. D
    Coolant sensor faulty?
    Hi everyone, I Noticed that the cylinder head coolant sensor has strange readings compared to the rest. Monitoring it today the coolant sensors are reading normal and the cylinder sensor is actually decreasing and hovering around 28 degrees when engine is up to temperature. I’m assuming...
  4. BFG
    Engine Coolant Sensor 2 location.
    A really simple question, but as a newbie I’m struggling to find the info. I have error code P2185 / 1606 which relates to “Engine Coolant Temperature Sensor 2” - Circuit high. It points to a faulty sensor / wiring, my question is, which sensor is this as there appear to be 2 or even 3...
  5. E
    Does anyone know which is the sensor that indicates the temperature on board a t6 2.0 biturbo?
  6. T
    Coolant temperature sensor
    Hi all, I have a 69 plate vw transporter and I have the EML on and get the code p218500 coolant temperature sensor 2 circuit high. Can you please confirm there are three sensors? One below the radiator, one in the block (i have changed both) and I think the other near the aux coolant pump. Can...
  7. C
    Which coolant sensor…
    Hi I’ve got a dodgy coolant temp sensor but could anyone shed some light on which one I need to replace? I have the slow 2.0 Diesel engine….. Thanks in advance
  8. R
    Hi all, I've had my T6 for just over a week now. Its a 2017 150 dsg with approx 40000 miles on it and today when leaving work the coolant temperature sensor has started flashing and the gauge was not moving up. I stopped the van and turned it on and off and it disappeared. Has anyone had this...
  9. coper6.1
    Coolant Temp sensor wiring
    Hi, my mates t6 plug on his coolant temp sensor has come off. Does any know what colour goes to what number please?
  10. Ali-G
    Location of Engine Coolant Temperature Sensor.
    Can anyone tell me location of the “Engine coolant Temperature Sensor” on the 204 engine please. My temperature gauge started playing up yesterday and I’ve got a fault code “00522 Engine Coolant Temperature Sensor (G62). I’ve searched the forum, googled it and searched on YouTube and had no...
