Erm....... how would one go about fitting fog lights to a Startline front bumper.........?
Mine also has parking sensors in it, if that makes a difference. Oh, and if anyone has a recommendation for some not too pricy ones let me know! Thank you!
Hi all. Got my new kombi. I’ve noticed when I start the van up 1 of the bottom spot lights at the front comes on. Any ideas ? Because Both lights do work
So I'm having an issue with my fog lights, and completely separate from each other.
Like most I leave my lights on "auto" (fog lights off) jump in and out of the van and never really worry.
Recently when you turn on the ignition, and start the engine, ONE of the two fog lights will also turn...
Hi, does anyone know if there's a separate fuse for the cornering aspect of the fog lights? Although the fogs themselves are working fine on demand (standard fit H11's on a my19 T6) they no longer light up when turning or when activating the indicator at any speed. I'm buggered if I can work...
Recently bought a t6 high line to convert to a camper, last night whilst parking I noticed my front fog lights were coming on when selecting reverse gear. Any help on this please? Have I damaged any cables when running the split charger cable under between the seats do you think? tia Jim
Just bought these for my 2018 T6. https://travelinlite-transporters.co.uk/collections/t6-front-lighting/products/t6-transporter-upgraded-headlight-bulb-kit-led-fog-upgrade-15-onwards
Amazing transformation and great price
Is it possible with VCDS to alter the speed at which the cornering light function is disabled. Seems the factory setting is 25mph. Would prefer 35mph. Can it be done?
