courtesy lighting
  1. R
    Combined courtesy and ambient lighting (white/red light)
    Thoughts please... I'd like courtesy AND ambient lighting that is white and red respectively. I figured I could modify these by replacing the switch function with a relay of some kind that switches between off/red/white...
  2. M
    Sliding Door Courtesy Light
    Hi Hoping someone can offer some advice here i recently went to change the sliding door footwell light on my T6.1 assuming it had blown however when i removed the light i discovered that there was no wiring attached to it so can only assume that this was something that the converters had...
  3. F
    Comfort dash- any courtesy lighting?
    I saw a 3d printed site with items for the t6 and in a few pics the phone storage space had a courtesy light. Nowhere on my dash is a courtesy light,phone storage/ glovebox, I haven't been able to visit another van. Should there be dash compartment lights ?
  4. Samro
    Courtesy lights on with ignition off.
    Most modern cars turn on the interior lights as soon as the engine is turned off, but my T6.1 only turns the courtesy lights on when the key is fully removed from the ignition barrel. This is a exceptionally trivial annoyance but I wondered if there was a clever way of tweaking the interior...
  5. t6mick
    Courtesy lights: canbus?
    could anyone please tell me if my courtesy lights are canbus linked or not thanks
  6. Daddio3750
    Step lights - Change from Courtesy to Ambient?
    Hi All, calling all electrical geniuses! Does anyone know if it is possible to change the step lights from a courtesy function into an ambient light function (ie fitted with blue LED replacement bulbs and on when the dash lights are on and not just when the doors are open. If you do know -...
  7. Taggy
    Upgrading Interior Courtesy Lights To Led’s
    Hi, I’ve recently brought my first transporter, a 2017 T6 and am looking to upgrade the interior lights to LED. I want them to be wired to my leisure battery as well as the courtesy light circuit that is standard. A simple relay circuit is probably all I need but I was hoping someone may have...
  8. F
    Courtesy And Ambient Lights
    Hello. I may be being stupid here but. I fitted my courtesy footwell lights and these work fine. Then I decided to fit @saxoboy light with ambientnleds and some ambient footwell lighting. these don’t appear to be working. I fitted saxoboy yellow wire to the blue Grey wire and also the...
