crimp terminals
  1. FerrisBFW
    Crimping tool for small VW connectors etc
    Can someone suggest a good crimping tool so I can properly crip terminals for the small connectors etc such as this please? https://www.ebay.co.uk/itm/186658370018?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=M0GxYqQ0Thm&sssrc=2047675&ssuid=mJBO7RsKQEq&widget_ver=artemis&media=COPY
  2. S
    Main and Battery Supply not Working after Jump Start
    Hello, neither my battery or main are operating after I had to jump start my van. Thoughts welcome.
  3. DubHaus
    Online resource for determining connector and crimp terminal part numbers?
    Not sure if it's already available, I did search! Is there an online resource that lets you cross reference the Connector Number detailed in the wiring diagrams i.e. T18a (connector on the Park Assist Module), to the part number i.e. 5Q0 972 718 A and then which crimp terminal part numbers...
  4. C
    T6.1 pax seat factory-LB wiring
    Hi, I'm new to the forum and have a question regarding my 2022 T6.1 Kombi. Under the single N/S passenger seat of a RHD Kombi is a long slim fuse box. This is fed by a fairly thick red wire which is permanently live and terminates and splits into a slightly thinner one and three thin ones which...
  5. Littleblackflash
    BCM Terminal Pins
    i need to add a wire into my BCM for my tailgate conversion. What’s the pin part number or where can I get some?
  6. Farnorthsurfer
    Battery cable crimping tool recommendation please
    Does anyone have a recommendation for the best type of low cost crimping tool to do my camper electrics? Specifically for the 6mm and 16mm tubular terminals to the DC-DC and batteries. I have tools for insulated terminals and bootlace ferrules. The only other thing missing would be the MC4 solar...
  7. RikParr73
    T6 Rear Light Upgrade - Replacement Cable Connectors
    Hi Recently upgraded my rear lights from standard on my 2017 T6 to ones from Travelinlite. After moving the cables in the plug around for the new lights a couple of the metal connectors became damaged and will not stay in the block. I want to buy replacements but not 100% sure what exactly I...
  8. C
    What type of connector is this?
    Does anyone know what type the connector blocks used extensively under the T6 seats are? I need to replace a pin/cable on one pin of one of them - how easy is this to do and what do i need? It is the green striped one in this photo (borrowed from another post).
  9. Littleblackflash
    Fuse Box Connection.
    Does anyone know the part number for the pins in the centre row of the centre fuse box? The outer ones are the same as the audio plugs but the centre row is smaller.
  10. SAF1981
    Scotchlok Or Posi Taps Supplier?....
    Hello, has anyone know a supplier or have a supply of either scotchlok or Posi taps that I can use to wire in some led bumper reflectors into the tail lamp looms? I can't seem to find a local electrician or supplier that has the scotchlok with the female seals.
  11. Grim Reaper
    Glove Box Light Switch?
    My van came without a light in the glove box, I’ve sourced an led one that fits in the cut out where a light should go but I then need a switch to operate it. Can anyone advise a part number and where it fits? It looks like it should go where there is a black blanking plug alongside the light...
  12. Eddie Sutherland
    Utilising Spare Fuse Slots
    Hi Guys, I have been running a couple of electrical items in the van that require ign and perm power. My fuse board has some spare ways that just require the out feed and fuse to be installed To,allow,them to be utilised. Dose any one know if this is Likley to cause any issues with canbus and...
  13. Josh Corps
    Fitting A New Fuse Holder
    Evening all, I'm retrofitting some seats to my van that have motors and are heated to that end I will be needing two switch lives under each seat. What is the correct way of fitting a fuse holder into a blank space? I don't want to get into the habit of piggy back fuses as by the time I've...
  14. superchargedpolo
    Rear speaker crimp part number
    Can anyone help. I'm fitting rear speakers to my T6 using the original head unit. I have the cable and speakers but just need the 2 crimps that click into the original head unit harness plug. I've done a good internet search but can't find the part number. Thanks in advance
  15. T6180
    Fitting rear speaker loom
    I've purchase a rear plug and play speaker loom with RCA connectors. If I discount the current loom and fit the new one will I need to enter a code into the stereo after? Also...how do I get access to the head unit?
  16. M
    [Guide] Enable rear speaker fader in a T6
    Hi, had some rear speakers fitted to my new t6. The speakers work but the fitter was unable to re code the head unit to enable the front / rear fader. Any suggestions... ?.
