Hi there,
Would welcome some direction on the VCDS errors regarding CC retrofited - I have tested CC and it works as it should (on/off/accelarete,reduce speed/increase speed/ clutch etc) but I get vcds error codes (note this is UDS one so no measure blocks but advance mesures which I tested...
Could someone tell me please
Transporter t6 2.0tdi 110kw 2017.
where I connect J428 (acc unit) pin numbers 2 (can high) and 3 (can low)?
I have pulled already the wires inside the cabin:
-Pin1 -> ground.
-Pin8->fusebox slot37.
i can't find the j788 relay. or the colors are in a...
Original cruise control kit with instructions and wiring loom.
Bought but never used.
Please check compatibility, this was bought for my old t5 and I remember something about it working with vans with electric windows or the multi function display. ♂️
£120 collection from Weymouth or postage...
Hello lovely T6 Forum people
Please would you throw your ten penneth in to this decision please?
I have a EUR5 Startline T6 without cruise control or MFSW and the MFD has the trip feature. I’ve always planned on doing the retrofit. I’ve read the hundreds of pages on all threads and understand...
Hi folks,
I am having a clear out of parts new and used and have come across an unused Cruise Control Kit for vans with MFSW and no rear wash wipe.
Comes with wiring loom and instructions. The loom is for LHD as all the cruise control kits are so will need at least 1 wire extending. Plenty...
Hi folks
I've recently retrofitted a MFSW with cruise control to my startline
Apologies for the blasphemy, but on my Caddy, there's an indication of the target speed on the dash, see below. I'm wondering if that's an option on a T6? Can it be done using VCDS?
Also, I've seen comments on a...
My van has a front sensor so would like to try and enable the adaptive cruise control. Could anyone recommend a obd2 /vag(?) Interface that I can use to change the settings, preferably cheaper the better lol
Hi.
New to forum and just bought a T6 2016 to convert to a camper.
purchased genuine VW retrofit cruise control and gave all the info requested for them to send the correct one and it came with instructions for a T5…
some of the instructions match what I’m seeing but stuck now as it tells me to...
Hi eweryone!
Can anybody help?
I have retrofitted cruise control and H7+H1 Caravelle lights to my T5.
Does anybody have adaptation lists for control modules on these old machines to turn on cc and change light settings?
I have Autocom in use, but it doesnt show adaptation list...
Last year...
I recently had cruise control installed on the stalk. Has been working fine for a few weeks but recently has started either switching itself off or putting this exclamation mark in the instrument cluster. This photo was taken (by me in the passenger seat while my wife was driving) today.
I have...
Hi guys,
i used the search function but i didn't find a solution to my question.
someone was able to instal cruise control on T6.1 150bhp?
I'm going crazy trying to get it installed on a customer's vehicle,
the van have OEM the leather steering wheel with mfsw, but without cruise...
i...
We bought a converted T6 startline 2016 in July, having done plenty of research over the lockdowns (including much of the sage advice on here, so thank you!) and it has been great, completing 2.5k miles in three months with long trips from Scotland to south Wales and France. Loved it. I...
Today I fix my cruisecontrol original in VW T6.1 2.0 (CXGD) It was not easy job, wiring Gateway soft...
but it is working!! yes I dit it first T6,1 in Europe with retrofit original cruisecontrol!
I,am happy!
Today I’ve had cruise retrofitted by Professional Retrofits - can’t speak highly enough about them. Brilliant job done in less than an hour and a half using genuine VW stalk - ‘enabled’ my display (even though this is a base ‘S’ Shuttle) - so all the lights, displays and read outs for cruise are...
HELP!!
Fitted a MFSW and now my van wont start!!
2015 T6 startline.
Fitted new cables to port behind wheel pins 9 and 10.
9 went to light switch - was meant to go in pin 15 but I only had 10 pins so i spliced with red and black wire.
10 went to pin 17 (spliced) in BCM. But now i am...
Disclaimer - use this information at your own peril - I may have got things wrong.
I am hoping this "how to" will be a one stop place for all the information, owners of poverty spec, 2019, EU6, T6's need, to fit a multi function steering wheel (MFSW) and to enable the cruise control system...
Hello all,
I own a 2016 EU5 Trendline with cruise control on the stalk - I would like to fit a MFSW. I think I’m almost there but just wanted to confirm.
Original wheel:
Steering wheel:
From looking at ETKA, there are 3 options, with each in black or grey? Can anyone confirm the correct...
Morning every one
As a new member I apologise if I am posting this one in the wrong place but I thought it was right.
I have recently got myself a camper based on the T6 Startline.
It hasn't got cruise control and I was wondering if it is possible to retrofit it myself?
I'm not too bad on the...
