cxeb engine
  1. Deansie
    Wastegate actuator adaption CXEB
    is there anybody with a CXEB and OBDeleven that could check what the wastegates actuatorvoltage is set to when ignition is off? I’m having trouble adapting the new turbo on my T6 and the workshop manual states that I should set a vacuum at 0,5 bar on the actuator and adjust the arm so the...
  2. L
    Wet Turbo
    Hello today I changed the glow plugs in my CXEB 204 ps and saw a wet turbo. When driving fast I'm leaking a lot of oil. Is it the turbo or the inside of the engine that needs work?
  3. Deansie
    204PS CXEB Bi-Turbo snapped small turboshaft
    Hi to all of you, From Sweden and new to the forum, searching the web for people with similiar issues brought my here with my broken van. The van is a 2016 VW Caravelle 204ps DSG 4Motion. Background: Bought the van from a VW dealership a year ago when it had ran 197500km (roughly 122k miles)...
  4. Dellmassive
    - 204ps Bi-Turbo CXEB T6 Engine & Turbo problems -
    - 204ps Bi-Turbo CXEB T6 Engine & Turbo problems - Looks like im the latest patient of the CEXB engine issues. (possibly the 2016-2018 range as there is a mention that the CXEB Block etc was revised in 2019) (the CXEC 199ps Bi-Turbo was released 2019> and revised ) in sort it looks like its...
  5. Andnik
    CXEB CXEC Injector question?
    As some of you may know my van has been torturing me with quite a lot of success. I recently changed the Engine as the old one was losing oil and water. So What I have now is a CXEC block in a Van that is CXEB.......fear not the Engine is Identical...and has gone in fine, however I cannot...
  6. H
    EGR Replacement or Not
    Looking likely that the some part of my EGR system is going to need changing, now the emissions warning light is permanently on. Since is a 2018 204ps CXEB engine, I'm paranoid that throwing away a large fee on the EGR is a waste, if the engine block is going to need changing. Am I causing...
  7. cottya
    VWT6 CXEB NON START After rebuild (2017)
    I am currently experiencing a non start issue on my CXEB engine. It blew one of the turbos in February, I pulled the engine and stripped it completely. I had the turbo re built and had the cylinders relined at the same time. With the re build I replaced all the necessary seals/gaskets lapped...
  8. Andnik
    Engine Change CXEB
    Hi Forum.....The green machine has been parked up for last 3 months with an engine that seems to be dumping oil.....I sourced a new low milage engine from Transporter heaven to transplant as lost all faith in old engine.....probably the small turbo has failed dumping oil into the Cat and DPF...
  9. W
    VW T6 204 Bi-Turbo - Engine replacement - £12k-17k What are my options?
    Hi all, Apologies such a long one on my 1st post but was hoping someone could offer some advise re an engine replacement for my 2017 T6 204 DSG Sportline. (CXEB Engine) Always dreamed of a camper and I bought the van privately just over 12 months ago with 100k on the clock, and obviously I...
  10. M
    2018 CXEB 150PS reliability
    Hi, I'm new to this forum and looking for advise. I have leased a 2018 T32 4motion Highline from new, engine is a CXEB 150kw. I am considering purchasing the van as the lease is up but slightly worried about the EGR problems mentioned so much. It uses roughly 1 ltr of oil every 5k miles but runs...
  11. P
    For Sale T5.1/T6 Engine / Turbo / Rack / Cluster
    T6 cluster 2017 7e0920s in gwo 150 T5.1 cluster 2014 highline gwo with immo chip 200 T6 electric rack ( will add part number 150 ) one rack end missing 2.0 t6 cxb full engine for breaking as started loseing water on a drive 2.0 t6 asorted turbos/ heads/ injectors. Just ask Pickup or post...
  12. D
    DPF part number help. Please
    Hi All, I’m really hoping you fine folks may be able to help. I’ve tried calling VW commercial van centres parts department and was on hold for 30mins with TPS earlier and gave up. I have a 2017 204 4motion CXEB and know someone selling a DPF and Cat. I want to know if there is a lot of...
  13. Tsixty
    Best DPF Monitoring App?
    I have Carista (because it does all that I need and is inexpensive). I notice that there are several specific apps for monitoring the status of the DPF and regens etc. What (Android) apps are people using specifically to monitor the DPF?
  14. B
    What is the compression on CXEB and wear limit?
    I asked my local VW dealer to measure and report on the compression as a guide to whether it is worth investing in a "Proper" camper van conversion or not. The report stated: 1: 19.25 BAR 2: 19.5 BAR 3: 21.0 BAR 4: 20.5 BAR They didn't supply any reference information so I rang them and they...
  15. P
    Advice please: potential 4Motion purchase
    Hi all.... just joined today to seek the collective wisdom of the forum for a (hopefully soon) purchase of a T6 Caravelle. Previously had a T5 and T5.1 but been out of the loop since the introduction of the T6. Could you advise on a couple of things? Firstly engines, is there a 204 and a 199ps...
  16. catfood12
    Oil Analysis shows high levels of Iron
    Mates I regularly get engine oil analysed, and never really have an issue. Report has just come back form the T6. 2017, 204 (CXEB), 45K miles. Oil is 12 months, 7k miles old, TPS Quantum 5W40, high levels of iron; For comparison, my 140K mile old Cayenne 4.2 V8D came back at 29PPM iron. A...
  17. Loz
    T6 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB 06.2016
    Workshop manual for the 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB
  18. Dellmassive
    T6 Service Intervals & Inspection, Flexible & Longlife
    T6 Service intervals & inspections , Flexible & Longlife : Im just posting this here to make it easier to refer back to in future . . . source: Volkswagen Flexible Service Regimes (Longlife) | Volkswagen...
