cxfa engine
  1. alter
    CXFA strange noise
    A problem friends, my engine, 2.0 cxfa from 2016, started making a strange noise... I thought it was the tensioner of the service belt so I tried to remove the belt but the noise remained.... I also replaced the timing belt including the water pump and the tensioner and pulleys, but nothing...
  2. Robert Hallyburton
    DPF suppliers
    2016 Transporter Shuttle 150PS CXFA engine. Looking like I may need to replace the DPF. At 280,000 miles on the original I cant really complain. I want to get another year out of the car. My question is who would you recommend to purchase one from. TPS have quoted £1700+VAT with a three week...
  3. ebiii
    Any idea if this is original ? CXFA 2.0 TDI 4 motion
    Hey ! I was fishing on my van to find from where my problems come and I am exploring the electronics option. (To make it short, gad a p0191 fuel rail pressure sensor and a p226d for a while, got the sensor replaced it corrected everything for 6 month) I know that the previous owner did put a...
  4. D
    Can the T6 run on HVO diesel?
    Hi all, For sake of the environment, I would like to know if the T6 (CXFA engine) can run on HVO diesel. Has anybody done that already? greetz / 73, Jan, PA1Y
  5. B
    Engine change CXFA to CXHA
    Hi All So firstly I know there has been a similar thread regarding what I'm about to cover but it did not really come to any conclusion. I have bought a very good condition 2016 T6 150HP 6 speed which is fitted with the CXFA engine that has the balance shafts but the van is high mileage and...
  6. G
    CXFA Engine needed after bending conrod
    Hi My 2016 Caravelle has bent a conrod and I am now looking to buy a replacement engine but not having much luck locating one in England. My engine code is CXFA can anyone recommend a company to try?
  7. D
    Howto prevent engine start?
    I have a T6, diesel, 2016 with a CXFA engine. In the past I had a petrol car with a secret switch. To start the engine I had to toggle that switch allowing the +12V to go to the bobine. The switch was in the +12V circuit to the bobine. When you try to start the engine and you are not aware of...
  8. ebiii
    Weird DPF Problems - [Resolved]
    Hello everyone, I have a small question and I hope someone can help me. So brace yourselves, I have quite a story below I have a 2016 T6 4motion 2.0 TDI with a CXFA 150hp engine and 50,000 km mileage. History: A cable gnawed by a marten, hence a repair and installation of a marten deterrent...
  9. RunDSG
    2017 204PS BiTDi - Seized turbo!
    I guess it's my turn? Driving up to Caravan and Camping Show, coil light starts flashing, ad blue suddenly low (topped up fully one week prior), no power. Engine temp fine, oil fine, engine sounds fine. Turned around and went home. Brought to a VAG specialist garage, they say: - split vacuum...
  10. Loz
    T6 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB 06.2016
    Workshop manual for the 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB
  11. Unimog
    Engine code CXHA and CXFA
    I understand from reading the VW Self Study Program 564 document, that the 150hp engine is available in two models. The CXHA and the CXFA, the difference being the FA is fitted with a pair of balance shafts designed to iron out bad harmonics. Does anybody know why there are two different models...
  12. P
    150PS engine installed in 102PS van
    Long, story short I’ve had to replace the engine in my T6 102 highline as the old engine killed itself (44k miles, and out of warranty). Anyway, I sourced a new engine a very low mileage CXG model and my mechanic has just fitted it. I made a slight mistake though, as it turns out the new engine...
