cxgb engine
  1. D
    Hissing noise when take foot off gas pedal around 2k rpms
    So I've joined this group to get to the bottom of this. The problem... When I drive and the van Gets over say 2k rpms, If let go of the pedal slightly and the van hisses. It will continue to hiss until I move gas pedal position. If I lift foot off ever so slightly the van almost jults/ hesitates...
  2. T
    I’m wondering which DMF will fit my 2017 T6
    Sadly think my DMF is coming to its end. Really bad juddering in reverse and first once it’s been driven and warmed up. I've put my reg into EURO car parts and it’s gave me a LUK 336441610 but the engine code is CAAB. I found a post on here which said my engine code would be CXGB. It’s a 2017 T6...
  3. P
    MAF sensor reading on T6 CXGB 85k
    Hi, I’ve just plugged a reader in to suss slightly high fuel mpg and noticed the MAF reading at idle at temperature was reading between 8.6 and 9. Is this a normal reading or should I look into it?
  4. 3
    EGR change on CXGB 2016 T6, do i need to do any calibration / adaptation?
    I just replaced the EGR valve and cooler on my CXGB 2016 T6, and it seems to be running well. Do I need to do any calibration / adaptation with VCDS or similar?
  5. R
    CXGB 102PS Engine Life Expectancy
    Hi, I'm hoping for some advice/pointers regarding my 2017 VW T6, which has a 2.0 litre diesel engine with 107,000 miles on the clock. I recently put the van into a trusted local garage, as the engine warning light came on. The mechanic ran a diasnostic check and it threw up four codes. One of...
  6. S
    VW T6 CXBG won't start after replacing injectors and CR pump
    Hello, I have a problem with my T6 CXGB 102HP. Unfortunately, the pump started to flake and unfortunately due to the shavings the entire fuel system had to be replaced. New pump and injectors (regenerated), fuel pump, lines, filters etc. Additionally, the timing belt was replaced at the same...
  7. G
    EGR Sensor 'A' (EGR Sensor '1')
    Hi there from not-so sunny Cornwall atm. Can any of you good people shed the light on this, I have seen it mentioned on previous posts but it never seems to get answered: I have a fault code P046C00 EGR SENSOR 'A" (1) My van It is not in limp mode and seems to be driving fine but can anyone just...
  8. K
    HP Fuel Pump Part number/cost?
    Can someone give me the part number of the High Pressure Fuel Pump and/or likely cost? 2016 plate Euro 6, 75kw/102bhp SGA CXGB 2.0l TDI.
  9. Super Dog
    Gearbox replacement 5 speed to 6 speed
    Has anyone swapped a five speed gearbox with a six speed?
  10. P
    HPFP delphi vs bosch CXGB vs CAAB
    Hi all! Does anyone know if the CAAB bosch pump is interchangable with the delphi CXGB high pressure pump? CRCP4S1R3520 vs HRP720 My transporter: -16 2.0 102 hp transporter euro 6 -CXGB Many thanks!
  11. Bulldogboy
    Top end tapping noise on cold startup
    Morning chaps I've recently bought a T6 102 PS on a 2018 plate ,with 54k on the clock. Its a V.W approved vehicle, a few times on start up, theres a pronounced tapping noise from the engine, after its been driven 100 yards it goes, and it doesnt always do it when you start the van, its only from...
  12. L
    CXGB ECU 4047 software update for P20EE
    Hello all. I get the P20EE 00 DTC, but no emission's warning light - yet. Friday,03,February,2023,19:55:03:16362 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-NET2 CB: 0.4623.4 Data version: 20221026 DS344.0 VIN: WV1ZZZ7HZKH01xxxx...
  13. Loz
    T6 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB 06.2016
    Workshop manual for the 4-cylinder common rail engine CXEB CXFA CXGA CXGB CXHA CXGC CXHB
  14. Sanyes
    Engine shaking (running on 3 cylinders) - error code P1007
    The other day, I started my van, started normally. ( It was cold outside but it started without hiccups) Made a few miles in the city, all was fine but when I get on the motorway, the van started to shake. Initially thought some motor mounts failed, wheels unbalanced something like that. After...
  15. Peter Rhymes
    EGR Error codes P023B and P24A9 [Resolved]
    Hi, can any one help? I have a P023B charge air cooler pump control circuit low and P24A9 EGR cooler coolant control circuit low flow. it seems to have appeared a couple of weeks after the cam belt was changed and the coolant was topped up. Any ideas please. cheers, pete
  16. P
    150PS engine installed in 102PS van
    Long, story short I’ve had to replace the engine in my T6 102 highline as the old engine killed itself (44k miles, and out of warranty). Anyway, I sourced a new engine a very low mileage CXG model and my mechanic has just fitted it. I made a slight mistake though, as it turns out the new engine...
