Hi all I'm looking for some help please
T6 cxha 150 ps t30 120k miles
Yesterday when driving on the Dual carriageway my van cut out I lost power and managed to get onto the hard shoulder.
I attempted to restart with no joy it was cranking over but would not attempt to fire up.
No engine...
Im looking to remove the oil pan on my 2017 van with CXHA engine.
So far there are two bolts in the back of the engine, by the gearbox that i cannot get to.
Anyone else tried this before, and have a solution? I have tried 1/4 rachet with socket (10mm) but the acces is by an angle and with the...
Evening all.
Apologies if this has been asked before, I have done a quick search but can't find a definitive answer.
The time has come for my EGR cooler to throw the expected leak. The one currently fitted is part number 04L131512T.
My question is, is 04L131512CF interchangeable? I can find...
Hello,
Long story short planning on doing my own cambelt change on my 2017 T6 CXHA.
I’ve studied Vag tech video and read manufacturer instructions but have couple questions.
1) Is it essential to loosen both Camshaft pulley and also high pressure fuel pump one?
2) I have noticed in videos...
Hello,
I decided to change an oil today. Last time I had it done at the garage and decided to do it myself today. So there’s my problem:
I’ve taken oil filter and it was twisted. I watched videos on YouTube and spotted that inside the housing there’s is spring or something and in mine there...
Hi T6 forum,
Hello from .
(New to this forum, but done countless hours of searching for simular problems.)
I'm calling out for some help/advice with our engine problem.
Long story short(ish)..
We bought a "project" car with broken timing belt (toothed belt).
Belt was split, but not broken...
Hello!
I'm in the middle of a cylinder head repair of a 2019 T6 with a CXHA engine. It has a teethless timing belt(~1,5 years/75k km driven) resulting to valve and camshaft module damage.
I already had the head refurbished with new valves and before I fitted the new camshaft module it seemed...
I am looking at replacing my clutch and DMF on my van 150ps 6sp CXHA on the weekend, I have managed to find the flywheel torque settings though the downloads in the VIP members area but unable to find the procedure for the clutch replacement.
If anyone could point me in the right direction or...
Hi guys having a bit of trouble with this code
P010100
Cleared it gave it 50km test drive came back on with the EGR low flow code. Checked my voltages to Maff sensor and pressure tested boost system can’t see no leaks at intercooler.
Could do with a hand if someone knew correct voltage at maff...
Hi All
So firstly I know there has been a similar thread regarding what I'm about to cover but it did not really come to any conclusion.
I have bought a very good condition 2016 T6 150HP 6 speed which is fitted with the CXFA engine that has the balance shafts but the van is high mileage and...
Good evening you lovely people
I am in need of some help , I have a MY 2018 t6 lwb 2.0tdi chxa engine code ,, I purchased the van about a month ago all good drive fine , since then the speed limiter has been upped bar that nothing , the issue I’m having is I I did a 70 mile journey no warning...
Contacted VW to request a EGR connecting pipe which I was led was part number 04L131521BH, however was told there are 2 potential parts dependant on which turbo I have installed on my van (150ps CXHA) and I would either need to get the turbo part number myself or bring the EGR pipe in to compare...
Hi all
The tensioner / belt is noisy on our 2018 CXHA engined, DSG, T6 so looking to replace it.
Doesn't look too bad a job (found the workshop instructions in the downloads section) but i'm not clear how to access it.
So do you do it from the engine bay or from inside the wheel arch?
Thanks...
Got some codes including 16056 Oil Pressure switch.
Can someone point me at the sensor location?
Some picies of CXHA engine would help.
Kind Regards,
Owain
PS its a CXHA engine.
2 Faults Found:
16056 - Oil Pressure Switch
P164B 00 [01100100] - Malfunction...
Hello i have some problem with my t6 2018 CHXA after replace Egr+cooler and the pipe on the backside. after a Quick drive like 3-6km i get 2 faulty codes
P4020
P0101
What can cause this problem?
Hello everyone,
Looking for some extra help with my pain in the a$$ transporter.
I got it a couple of years ago and the speedometer just turn over 210.000 km. It suppost to have got the timing belt and water pump changed but obviously not.
Had it running on the highway and out of no where i...
Greetings, can anyone tell me the part no for the ‘glow plug control module’ on a 2016 euro 6 t6 2.0 tdi 150? CXHA.
I want to replace as I have had a few intermittent errors relating to the module under the battery tray. But on visiting several parts websites I get different results and totally...
I had an issue with cylinder 1 glow plug on CXHA engine.
Replaced all 4 glow plugs yesterday.
To try and make my life a little bit easier, I remove the fuel rail for access to the glows.
I have Carista which has a fuel system prime function.
Carista say, to be used when replacing injectors or...
