dash cam
  1. Smileysmile
    Positioning of rear dashcam camera T6.1
    I've just purchased Auto Vox pro mirror with built in dashcam and reverse dashcam camera, the size of the reverse cam (photo attached) could fit in the same location of factory reverse cam. Would this be ideal position? The panel the factory reverse camera fits, is it plastic or part of the...
  2. Smileysmile
    Has anybody got a Wolfbox dashcam?
    I'm looking at 4K dashcam front and rear for T6.1. I quite fancy being able to look at what I'm recording especially from behind. Does anyone have one and do you recommend it? Wolfbox dashcam
  3. Paul Sussex
    Dashcam angle
    just had a Road Angle Halo Dashcam fitted today at Halfords. Took a while as the guy wired it wrong long story - still not sure it is right as don’t think parking mode working (so maybe not taken live feed only ignition side) will check in morning. The question for today, it is not mounted...
  4. Jamiev
    Alpine Halo dashcam???
    Does the Alpine Halo series have dashcam functionality with the additional camera, or do you need to fit a specific dashcam? I’m looking for a dashcam, revering cam and head unit and it would be good if they worked together. Thx
  5. D
    F770 dashcam - how to find power supply? Would like to make sure it's connected to leisure battery
    I'd like to check which battery my F770 dashcam is wired to. Is there any smart way of doing this? I'm about as far as you can get from an auto technician, but I can follow clear instructions... Mine is a 2017 with factory leisure plus a fair amount of extra electrics stuff (towbar, inverter...
  6. S
    losing DAB radio after wolfbox install
    Hi i have just fitted a Wolf box G900 dash cam to my rear view mirror and today the DAB radio has lost signal or just keeps cutting out, i have a T6.1 with i believe the ariel is just in front of it , in middle of windscreen. Has anyone else had this issue and how did they resolve it as , b4...
  7. T6 Owl
    Garmin Rear Dashcam Wiring
    Hi all, I have just purchased a Garmin Dashcam Mini 2 to use as a rear camera in my T6. I have also purchased the Garmin parking mode cable to wire it in permanently. However I need to find an ‘Accessory 12v’ feed, i’m presuming this is a switched/ignition live? Where would I find a switched...
  8. I
    Dash-Cam installer - Milton Keynes
    Hi Bought a VW T6 2019 converted campervan t28 with solar and leisure battery. All works fine after replacing split charger. Am used to reversing camera on work vans so I need to install one or even get it done for safety - these vans are big. Prob better to put front +rear at same time. Am...
  9. Jimmmmy
    FitCamX Dashcam (power from rain sensor)
    Wondering if anyone has one off these as they look really good and the reviews on U tube are good too, a OEM looking dash cam that connects to the rain sensor power behind the rear view mirror and replaces the trim at the front for a camera, available fro most makes of car and van...
  10. Smileysmile
    Routing Dash-Cam Cable through Tailgate
    Struggling to route rear cam cable through rubber tailgate rubber gaitor. Its so tight. Thoughts please. Photos attached.
  11. H
    Dashcam hard wiring fuses to use
    Hi, I recently purchased the AutoVox V5 Pro dashcam and reverse camera. Having looked around on the forum (@Lox fuse diagram) and other places for which fuse I have come to the following conclusion: SC17 for the permanent live SC36 for the switched live Both locations have been marked up in...
  12. T
    Wolfbox G900 hardwire no 15A fuse available
    Hi all, I picked up my van on Thursday and had already bought the Wolfbox G900 no forseeing this problem. Firstly, this is my foray into doing anything myself with a vehicle so I have been watching YouTube videos to see how it’s done. I had a fuse issue on Friday (now fixed) which caused me to...
  13. A
    Dash cam Hard wire kit
    Hi All, I am trying to install my hardwire dashcam kit with fuse taps (T6.1 fuse box under / right side of the steering wheel). Can someone point out which fuse i should use for the permanent live and switch live please? Any help would be appreciated.
  14. T
    Dash cam - how does it work?
    Hello I have front and rear dash cams in my new to me Van (had it 3 weeks). Not sure if they are factory or not I've never had them before how do they work? How do I operate them? Photos attached of front dash cam Thanks
  15. C
    T6.1 Blackvue Dashcam Install
    Hi all, I have the BlackVue DR750X-2CH Plus which I want to hardwire into my 2022 T6.1 transporter. I need to find a suitable permanent supply and a switched supply in the fuse box. I will earth it somewhere on the body. VW don’t supply a diagram so I am struggling. Here is a pic of my fuse...
  16. A
    What’s this cable by my internal mirror for?
    Hi All, I’ve been wondering, in my T6.1 70 plate Transporter high line I have this cable here. I’m unsure what it’s for, can anyone help? Thanks Alex
  17. C
    Wireless dash cam?
    Hi, Another newb question as I have been frustrated by a Halfords (4 visit and multiple assurances) dash can saga. Hillside birch over all carpet lined inside causing much perturbation amongst Halfords folk. Does anyone have any experience of wireless rear camera) systems. I have had...
  18. P
    Dashcam fitting, front and rear - costs?
    Hi folks. Picking up my new T6.1 conversion in the New Year. Got a lot useful info here already. Have been reading the dashcam threads too and think I have settled on the Thinkware F790 front & rear. The convertor hasn't fitted one before but reckons 3-4 hours labour at most @£30+VAT per...
  19. C
    Dash Cam Mystery
    Hi, need to rack some brains on a baffler for me. I have a 21 plate T6.1 and want to hard wire a dash cam in. I've fitted a number of hardwired dash cams to various vehicles over the years so am pretty confident I know what I'm doing. I sourced a good earth and live feed and put a multi meter...
  20. Samro
    T6.1 12v socket permanent live
    My T6.1 appears to have permanentlylive 12 cigarette sockets. (I didn't have a factory fit leisure battery.) Where is the best place to get an ignition switched live?
