dc - dc charger
  1. V
    Battery help - Auxiliary, leisure and powerstation
    I have a 2018 T6 Startline that is about to be converted. I will be adding a leisure battery for diesel heating, lighting etc. I am looking at the Roamer 230SEATBASE4 or similar. I would also like to add a powerstation (Ecoflow Delta 3) that can be removed from the van if requried, but that will...
  2. C
    Orion 12/12/18 keeps switching off
    As per this heavily supported install thread- https://www.t6forum.com/threads/l-battery-go-large-or-go-lithium.52433/page-26 I seem to have a new problem. whilst driving approx 2 hrs motorway. Noticed LB charger to up from nearly nothing to 39%, and then no further. Further investigation I...
  3. T6VanLife
    240v to 12v DC Power Supplies.
    Can anyone recommend a quality 240v to 12v DC power supply about 150-250w ? all I can find are these cheap ones on Amazon & eBay which I am not sure I trust ! https://www.amazon.co.uk/dp/B08GKS26CJ/ref=twister_B0CQR3R3VY?_encoding=UTF8&psc=1 As I want to power my diesel heater and some 12v...
  4. J
    cable routing
    Hello all, am looking to install the renogy dual dc charger under my drivers seat but need to get a cable from under the drivers seat to the fuse box of my t6.1. Any ideas of the best route, ideally under the floor, seems most logical , however that is rarely the case
  5. S
    Renogy 40A DC-DC charger- charging when engine has switched off
    Hi all, i have installed the Renogy 40A DC-DC charger (see picture below for model of charger) in my T6 but im having issues. When the engine is running the Charger works fine and charges my leisure battery however when i turn it off, it contiures to charge. I have used a piggyback fuse on an...
  6. BoroBoy
    For Sale Sterling BB1230 Battery to Battery Charger.
    B2B charger for sale complete with Users Manual. This unit has a LifeP04 profile. Asking price £50. Postage can be arranged at buyers costs.
  7. C
    L/Battery - go large or go lithium?
    Hello all, I am working up courage to swap split charge relay with a Victron DC to DC and Ablemail 12-2. I only currently have a 75 sized leisure battery. So was thinking of changing that too for a bigger capacity. This is all under driver seat (impacted by diesel heater dusting). I have...
  8. J
    Voltage Sensitive Relay or Battery to Battery Charger for LiFePO4?
    I am installing a solar panel with lithium battery and was hoping someone could recommend whether to use a Voltage Sensitive Relay or DC-DC (battery to battery) charger so that I can charge the leisure battery from the starter battery when the engine is running?
  9. R
    Victron DC DC Charger - charging issue
    Hi all, Apologies, I know this probably gets asked all the time - I have emailed the garage that fit this for me but they haven't come back to me yet. They fitted the above with a new Leisure Battery and it worked great, I had the app open whilst driving occasionally (hands free) and I could...
  10. R
    Sold Renogy 50A DC-DC On-Board Battery Charger with MPPT
    £200 Brand new - opened box to look at but not taken out. Included in the sale of the van we bought, we are not going down the leisure battery route so is surplus to requirement. DCC50S 12V 50A DC-DC On-Board Battery Charger with MPPT(New Version) - link to details
  11. T
    Victron 75/15 BT with Orion B2B
    Greetings. As I run an AGM leisure battery, and the van sits for sometimes a week at a time without moving, I want to keep the leisure battery topped up when not driving, so it’s pretty much always ready to go. I currently run a victron Orion BT non isolated. That sits on a board in front of...
  12. Catmalvin
    Sold Full EHU set up including Victron IP65 15a charger
    I have just removed my full EHU set up including Victron IP65 15a 12v charger. Only removed as I have since added an additional battery solar and inverter for off grid use so no longer need. This was all built to be hidden under the bonnet for invisible hook up. Full kit includes Wylex IP65...
  13. Euge
    Victron DC-DC doesn’t appear to be charging LB
    Can anyone help please. We’re driving to Scotland and the LB doesn’t seem to be charging from the Viktron DC-DC. Looking at the Viktron app it says Bulk Charging but the LB voltage isn’t increasing. After a 4 hour drive I’m still showing 12v on the LB and we started at 12.1v. Nothing is powered...
  14. S
    Victron Smart DC-DC 12/12/30A Isolated Charger with Smart Alternator?
    Hi Guys, Been reading a few threads looking for settings. I have a Victron Smart 12/12/30 isolated charger and the van has a smart alternator. Both negatives on the isolated smart charger are connected to ground (not sure if that makes a difference - but wanted to check). Smart charger is...
  15. Dellmassive
    Sold REDARC BCDC1250D - 50A DC-DC Charger & MPPT Solar Controller
    REDARC BCDC1250D - 50A DC-DC Charger & MPPT Solar Controller (with Lifepo4 profile) 50A DC-DC + MPPT with 32V VOC input +++++++++++++++++++++++++++ top of the range DC-DC charger. ( 1st one in the country) smallest combined unit available at the time. as new, was only fitted for testing...
  16. BoroBoy
    Renogy DCC50S 50A DC-DC Charger + MPPT + Renogy One + Renogy BT2
    I have the above equipment for sale. Recently bought to upgrade my current Sterling DC to DC charger. I have decided to ditch the upgrade project due to difficulty in running larger cables for the 50 Amp unit. Item for sale is the same package as attachment. I am looking for £250 if collected...
  17. TeeCeeJay
    For Sale Sterling Battery to battery charger BB1230 £80
    Sterling Power BB1230 battery to battery charger. 12 volt 30 amps. Has lithium and AGM profiles. Please note this is not the MPPT version, so no solar input. £80 collected. Can post at cost.
  18. Dibsta
    Victron orion xs 12/12/50a
    Hi all anyone know who as stock of the Orion xs 12/12/50a Thanks for looking
  19. A
    [Resolved] dc-dc and starter battery fuse blown
    Hi there, I'm looking for some advise what is going on with my connections i.e.: I have finished installation yesterday with renogy dc-dc/mppt 50A to my fogstar 230Ah. See below diagram And everything worked i.e. including load however, I decided to leave victron charger on to recharge LB and 4...
  20. P
    Anker Solix Dc to DC charging
    Morning all. I've bought a Anker Solix power bank. On the standard 12v Cig lighter it takes for ever to charge up. Has anyone done a Dc to DC charging set up ? Thanks
