diff lock
  1. andrewburtenshaw
    Quaife ATB on FWD T6 6-speed
    Anybody have any experience of having a Quaife ATB limited slip differential fitted to an FWD T6? Mine's a 2018 150PS 6 speed Highline van with the 17" Devonports and a set of Agilis CrossClimates fitted. Stock T30 suspension. I'm looking to achieve better traction on wet campsites, muddy...
  2. bootsam
    VW T6 Diff Lock Stuck on
    Hi, I havent used the van for a few weeks now. Went to use it today to go to work, everything fine until I turn into works road, then I get the 'skipping' feeling. I note diff lock is activated. ? I never activated this. Now it wont deactivate? I have vcds at home, but obv at work right now...
  3. D
    For Sale 2021 LHD T6.1 4Motion Camper. £39995
    For Sale T6.1 LHD 4 motion 2021 November 2021 VW T6.1 6 speed manual 4motion Transmision,Differential lock, onboard computer system with Apple car play, air con ,Reimo pop top with lux sprung bed,Reimo bench seating with track system, fully removable with fold down mattress on reverse,Full...
  4. bootsam
    2016 T6 4Motion - 4wd light came on and beeps
    Hi, Just recieved notification that the 4wd icon popped up on dash on wifeys way home. No other alerts. Any ideas? I have a vcds. But im at work.
  5. A
    Sold 2021 T32 SWB 199PS DSG 4Motion Diff-Lock Kombi Highline. £55k
    Due to family getting older and wanting to experience things on their own more, holidays with mum and dad are getting far less attractive. Mum’s also not so keen if truth be told. So unfortunately my van is not really serving any purpose for us anymore. I’m reluctant to move it on, it’s a bit...
  6. P
    4motion diff lock ?
    I've seen a t5.1 with rear diff lock ( had a type off plastic actuator mounted on the rear diff ) But on the 2018 rear diff chap said it had diff lock .I'm confused. Anyone know . Only details I have is. 4motion set up is from a 2018 204 2.0 diesal lwb Rear diff module is 0ay 907 554 L
  7. D
    Diff lock failed again
    So, 12 months ago I had both solenoids changed on my diff lock (T6, 199hp caravelle 4M). One was burned out, the other simply didn't work. The locker has worked fine up to now and I have made a point of using it at least once a month, indeed it's been great pulling a caravan out of a campsite...
  8. P
    Advice please: potential 4Motion purchase
    Hi all.... just joined today to seek the collective wisdom of the forum for a (hopefully soon) purchase of a T6 Caravelle. Previously had a T5 and T5.1 but been out of the loop since the introduction of the T6. Could you advise on a couple of things? Firstly engines, is there a 204 and a 199ps...
  9. chris ratay
    4-motion or 4-motion with 1Y4 locking rear diff - what I've learned
    I just purchased a new Ocean for Overland Travel and thought I'd share some things I learned during my research. I knew about 4-Motion before I started shopping, but didn't realize early on that a Locking Rear Differential (1Y4) was even an option and almost made a purchase I personally might...
  10. D
    4motion difflock staying on
    Hi my difflock has started coming on and won't go off. I had the Haldex unit replaced a couple of years ago. Anyone else had a problem with this ? It's booked in to norwich vw but not until the 17th Nov. Any advice please
  11. T
    Disable t6 diff lock.
    Hi. Just today in the wilds of NSW, heard unusual noise outside when turning on a gritty town street - noticed the diff lock had turned on, all by itself. Not an accidental bump. Does not cancel with button. Comes on repeatedly when driving off at low speed, and warning sounds when up to a...
  12. chris ratay
    T6.1 Retrofit rear diff to 4Motion
    Planning to purchase our next overland vehicle for global travel, and looking to buy a newer T6.1 Ocean 4-motion, European (LHD) version. I'd like to get the locking rear Diff, but need the van in the next few months, so don't have time to wait for a custom order. Assuming I won't be able to...
  13. Pauly
    T6 AWD All Wheel Drive Wiring Diagram 2017
    AWD 4 motion circuit diagram Also covers elements of diff lock, ABS and steering angle sensor VIP Membership is required to download this document
  14. Unimog
    If you turn on your rear diff lock, does the ECU activate the Haldex to fully engage?
    If you turn on your rear diff lock, does the ECU activate the Haldex to fully engage , or do you still have to wait for the van to loose grip before it engages the 4 wheel drive? Thanks
  15. boopzz
    4motion diff-lock activation
    So I bought a T5.1 T30 LWB 4motion last summer with the diff lock option. It has the button and when you press the button I can hear a click of a relay so I assume its ON but cant see any other indicator lights to say otherwise. Could someone confirm if I should get some kind of feedback? Or if...
  16. T
    Why Buy A 4motion And Not Get The Diff-lock Option ?
    Hi, I'm going to try and politely kill two birds with one stone here......so bear with me I'm a great believer in if you're going to to job, do a good job properly once, rather than a poor job two or three times. With that in mind, why do people go to the lengths and costs of buying a 4motion...
  17. Sturge
    4Mo: with or without Diff Lock?
    Hi Another question.... Almost ready to push the button today on a T32 204 DSG 4motion today, but realised it doesnt have the diff lock option on it. My motoring is predominantly road, but want 4motion for the potential snowy conditions in the alps and also if we get bad conditions over here...
