direct tpms
  1. N
    2021 transporter multivan tpms
    Abs and traction control light on Fault code in abs 0447 tpms display[c1146 f0(10001001) not available.. All abs sensors have been graphed while driving and are all good. Any ideas
  2. EAN
    Wheels already fitted with VW TPMS sensors
    I’m, possibly, about to hit the buy button on some OEM VW Manaus alloys that were demo wheels from the VW factory. No tyres but they’ve still got the TPMS sensors in. My T6.1 doesn’t have direct TPMS. Stupid question but do I leave them fitted and ignore? Or should I remove and is it easy to do...
  3. Jeidmaster
    Disable tpms, carista ?
    Is it possible to disable TPMS with Carista or do you need someone with vcds to do this Also seen some odb plug ins to use as a way of disabling it Assume they need to be constantly plugged in as a bypass though Just asking as new 20” wheels coming and was told they don’t send out with the...
  4. D
    Sold Devonport’s - almost new only used for 1k miles. £550
    Originally supplied on my T6.1 these are as the description and include the TPMS sensors and wheelbolts with locking wheelnuts. Tyres are Goodyear Ultra Grip Cargo. Pickup Near Aylesbury or Guildford £550 ONO
  5. D
    Sold AXE EX40 20" Alloys and Eagle F1 tyres - 8.5J ET40 275/40/20 tyres - Wheels and Tyres
    Originally fitted to my T6.1 these wheels are in excellent condition with no kerb damage. Original paint. Includes AXE centre caps and TPMS valves. Average measurements across the 4 tyre measurement points are 3.9 / 3.2 / 2.7 / 2.2 for the 4 tyres. All 4 wheels are the same size 8.5J, ET 40, 20...
  6. J
    T6: Tyre pressure monitoring unavailable' / 'ABS controller error (ESC) [Resolved]
    Hi, purchased a Highline T6 back in 2016. Sadly it has been an expensive disappointing experience. Will be selling it soon. My main dealer's service is slow. I now have an ABS issue Error messages either approximately state 'Tyre pressure monitoring unavailable' or 'Abs controller error (ESC) I...
  7. M
    failed mot on Tyre pressure warning light. need help getting it off, resetting tpms - London based
    Hi there, I've been running 20 inch wheels on my 6.1 combo for three years and Ignoring the tpms warning light. all fine love my van. until mot today and now I'm a bit fooked. I know and understand nothing about the vags Odis stuff etc but what from what I can make out VW are absolute f***tards...
  8. B
    T6.1 direct TPMS reset .
    Hi all , I’ve upgraded wheels on my T6.1 and installed the existing TPMS sensors in the new wheels , on the main screen (centre dash ) the tyre pressures all ok on Direct TPMS section but on main dash the light flashes for tyres pressures and then stays on after a short distance . As one...
  9. W
    Tiguan 2018 Direct TPMS installing
    hello guys , i need help if you can into installing & coding TPMS SET to my tiguan 2018 >>> i bought a tpms system pack from AliExpress (Module& 4 Sensors & harness ) first problem i faced that after research i found some guides did this installation by connecting the two wires from tpms module...
  10. BikerPa
    T6.1 Direct TPMS sensor suppliers? for OE Pt No.2N0907251 in UK (Other than VW CV)
    Has anybody found a reliable supplier (preferably online in UK) of these TPMS sensor valves other than VW CV franchises that charge £90 ea. for them? OE Pt No. 2N0907251 (manufactured by Schrader) I've tried some other after-market Schrader Ez-TPMS sensors which work for a while but then the...
  11. huw169
    TPMS - how it works
    Hi all Had a read through the other posts on this, but doesn't answer my questions. I can see that the new T6.1 appears to have a 'direct TPMS' so needs the sensors in the wheels, but the T6 is monitored off the ABS. I'm picking up a T6 Jan 2019 model in a week or so, and keen to change the...
  12. M
    T6.1 TPMS, with reading in display.
    Hi I just bought a new Transporter T6.1. Of course, the car has TPMS, but not with direct reading of what the pressure is in each wheel, in the display. Is it possible to code it to display it with VSDS connectors, or do you need extra hardware? - Mads
  13. Robert
    Direct TPMS Retrofit
    This is possible on PQ25 platform so why not put it on T6:sneaky:
  14. Shaun Witts
    Can Tpms Be Enabled On A Panel Van With Carista Or Is Vcds Needed?
    I’ve just collected my Highline 204 TSI panel van and am preparing a list of what Carista can do for me. The list is as follows, but can it enable the TPMS as well or can this only be done with VCDS? Tear drop wiper sweep 5 instead of 3 indicator flashes Drive away locking DRL wink option 1...
  15. conrad
    Direct TPMS?
    I have seen threads about indirect TMPS systems been activated for those vehicles were the `change in law' did not apply but has anybody managed to work out if a Direct TMPS system is built in and could it be activated? I have a DTMPS on Jeep Renegade and I find it really useful, seeing which...
