door card lighting
  1. Andysmee
    Ambient lighting - adding to door cards and lower dash
    Again, not a fully fledged [GUIDE] as there are lots of ways to personalise this, but here's the steps. In the doors you can tap off the window switch backlighting (above) and in the lower dash you can tap off the dashboard backlight dimming switch or the headlight switch (below) and any...
  2. Sabre
    door card LED
    Just been looking throught the other threads on this as I have put my own 'downlighter LEDs' into the door pockets, (only one small faux-pas with passenger side being too close to the back wall, but thats manageable) but, also drilled the back of the door handle in the centre to fit a LED in...
  3. Big.mac
    Courtesy light circuit
    Can anyone tell me if the Courtesy circuit appears inside the front doors please. It will save me taking the door cards off and hunting through all the cables.
  4. P
    Door Card Light
    Does anyone know the part number for the ambient lighting behind the door handle lever??
  5. 496F79FF-11D2-4DFE-8A74-865736BE0DA4
  6. D77556ED-E56B-4A27-8ECC-1D98E505277C
  7. Sturge
    ambient lighting in doors
    Just pricing up caravelle door cards, and want to put in ambient lighting. The dealer has included a wiring loom at £315 per door (!) - part number 7E2 971 121 J I imagine there must be a lighting connector that i can tap onto without needing a new loom for the door? Obviously this is a big...
