door lock microswitch
  1. neekstan
    Sliding Door Intermittently not unlocking on remote
    2018 - T6 Transporter (not under warranty) - Quite often when I unlock the vehicle using the remote fob the sliding door doesn't unlock and takes one or two additional presses before it unlocks and the handle then works to open the door. Any ideas/suggestions welcome. Thank you.
  2. H
    Driver door intermittent latching
    Having an issue with the driver door not latching . Seems to bounce back . Occasionally it will latch . It seems like the the little end piece on the door latch won’t sit back flush to the door (photo shows it sitting flush) . Any ideas? Cheers
  3. J
    Drivers door not locking
    Hi. I'm about ready to throw this all out the window, "THE VW CAMPER EXPERIENCE". What a money pit, as we all know but tried to defend the reliability part saying the money went on personality but no more, i've taken the EGR on the chin with less than 35000 on the clock wilhich was best part of...
  4. J
    Sliding will not lock from remote key fob.
    Hi, my sliding door has stopped locking from central locking remote. All the others door lock and I can manually lock it from the key. The door will however unlock from the central locking remote. Any ideas anyone? Thanks in advance for any advice!
  5. Stu007
    T5.1 door lock issue - lock /actuator part number?
    I have the dreaded door open sign when the door is locked and had the alarm now go off once thinking the door was open :-/ does anyone know the part number for the driver side door lock actuator for T5.1 2015? See there are loads of super cheap on eBay compared the oem vw parts. Thanks in advance
  6. N
    Sold Sliding Door Manual Control Module
    £40 collected from Pontypool, South Wales or could post at cost. This was removed from 2016 Kombi near side slider when investigating issue with opening from inside. Issue was actually with child lock switch on driver’s door but decided to keep new part in situ. Not tested but at £170 from...
  7. A
    side door need to be unlocked twice
    Hi, I have electric sliding doors, both sides. I also have autolock over 20km/h active, so each time I drive they are locked. However I've noticed some time ago that left ones need to be unlocked twice to allow opening, while rest (front and right ones) are "ready to open" after one unlock. It...
  8. S
    Sliding Door locking
    Hi, 19 plate twin slider T6. Drivers side sliding door now wont slide or electronic lock. Checked door contacts, Checked 40amp fuses and power all there. I did notice that the interior lights are being activated either when I open the door. Did I read somewhere there is a micro switch in...
  9. T
    T6 sliding door won’t open from the inside?
    2016 T6, new to us. The sliding door opens fine from outside. But will not open from inside. Is there a simple fix.?
  10. fpdizzle
    Central Locking Issues with slider / rear doors during cold weather
    Morning all. I’ve had a T6 Camperking conversion for 3 years now and have discovered an intermittent fault with the central locking. On some occasions (but mainly on cold / freezing mornings) I blip the key which turns the headlights on and opens all the doors apart from the sliding side door...
  11. DMXDAVE
    T6.1 Door Control Unit Defective - ongoing two years
    Has anyone else had a problem with their Door Control Unit Defective. I'have had this on and off for the past two years. The Birmingham Van Centre replace this under warranty 21/12/2023 and then 12 days later I get the same message and error. It has just fallen out of the 3 year warranty so they...
  12. P
    T6 central locking module help
    I have 2 door modules from either a t6 or t6.1 which I have the plugs but there all white wires Looked in download section but unsure on pins Anyone up on the 8 pin plugs ns os need to get my van on
  13. D
    T6.1 tailgate was opening by itself and now won't open at all
    For a couple of months, my tailgate would unlatch itself - usually as I was at a standstill at traffic lights or waiting to turn. On one occasion I noticed in my wing mirror that the tailgate was fully open - thankfully nothing had fallen out. Now the latch doesn't work at all. I have to use...
  14. L
    Barn door not unlocking from inside
    After a few days out with van my wife returned this morning saying the barn doors wouldn’t open from inside ? It opens fine from outside but not inside Checked the deadlocks were not engaged etc I assume this will be covered by our 1st year warranty from the dealers p
  15. S
    Central locking and key fob not working properly. T6 Combi 2019
    Hi A few weeks ago I closed my tailgate on a full boot which then jammed. I couldn’t open the boot externally and managed to open it using the internal switch (T6 Combi). I noticed that a folded table was pressing against the area of the internal switch. All seemed well until later I tried to...
  16. J
    Central lock on driver door not working, but works from key FOB
    I’ve read all previous posts (I think) regarding central locking issues, but couldn’t find my issue. Need someone to brainstorm with. I have a T6 Multivan from 2016 (highline, 2.0 bitdi). Last week central locking when using the switch on the driver door stopped working. It locks all doors...
  17. M
    Barn doors won’t open at all
    Went camping this weekend and completely out of the blue my rear doors on my t6 just won’t open! Tried wiggling the lock woth key, tried from inside and outside (can access through sliding door!) The middle and bottom latch open, but the top latch on the near side door is not releasing! Any...
  18. howlingmonkeydog
    Help! Drivers door lock assembly just comes out!
    Can anyone help a newbie? Just went to open the door, and the whole lock assembly just came away. How the heck do I fix this?
  19. F
    Drivers Door Lock mechanism / Switch
    Drivers door sensor not working, doesn't show that the door is open on the dash so the van locks the doors on the timer - dangerous for locking keys in the van. Tried WD40 on the catch, no point, didn't work. Bought new mechanism off ebay and fitted it today. Top tip, buy some multi spline bits...
  20. Constalation
    [Resolved] Sliding door rear catch issue
    I have an issue with the door catch at the rear of my sliding door. I have taken it out and freed it and greased it in the past which worked but it is sticking again. This fault stops the door locking so I want to replace it. Does anyone have a part number? Van is a 2017 T6 204 Kombi
