Hi Guys, I need to separate some Caravelle Door cards that i have purchased as i want to recover them in Alcantara. From the bottom picture does anyone know if both the red and yellow marks need to be ground away to separate?
Can't have too many "how to" threads with pics, so here goes...
Quick steps to remove door card (EDIT: this is the driver's side, but the passenger side is exactly the same steps, just fewer connections)
1. Prise off trim on handle on door card (little slot to below rear to put a screwdriver...
Looking at replacing my plastic looking door cards for Caravelle ones. Clearly cheaper second hand off EBay. Has anyone bought the cards from Poland? They are mostly for LHD, do these readily fit a RHD van. Looking for any gotcha’s really?
Can anyone tell me if the Courtesy circuit appears inside the front doors please.
It will save me taking the door cards off and hunting through all the cables.
Hi Guys, as pictured T6 lowerdash trim from a 2018 (68) T6. Minor wear in the pictures and the drivers door pocket has a hole for a usb socket. Open to offers. Kev
I’m in the process of adding sound proofing to my kombi (as VW obviously don’t think it’s necessary) and my next challenge is the front doors.
I’ve had a search or two but can’t see any obvious threads that would help me understand how to get the internal panels off the front doors.
Could...
Transporter door cards taken from brand new van in 2018. Includes window switches (see pics).
£100 for the pair, collection from North West, near Chester or buyer arrange collection. Payment cash on pickup or paypal friends & family (or you pay the fees :)).
Removal and installation are described only for the left side. Re‐ moval and installation of the right side is similar.
Window regulator, door lock and loudspeaker are secured to the assembly carrier.
The door lock can be removed only together with the assembly carrier.
Assembly carrier can...
One of the biggest disappointments with the Kombi is the zero effort approach to the door cards in the passenger compartment of the Kombi. The cardboard isnt cutting it for me.
Is there a common OE upgrade people do? Like whatever comes on a multivan? I guess as usual these will demand crazy...
Right, so I've fitted a dash cam and successfully pulled things apart and put them back together again so..... Now I'm fancying taking the door cards off and fitting some new speakers and applying a touch of Silent coat or similar. Any tips please.
Would you recommend applying the sound...
Just pricing up caravelle door cards, and want to put in ambient lighting. The dealer has included a wiring loom at £315 per door (!) - part number 7E2 971 121 J
I imagine there must be a lighting connector that i can tap onto without needing a new loom for the door? Obviously this is a big...
