drop links
  1. C
    Clunk clunk clunk
    Last summer our van started making some rotten clunking noises on uneven road surfaces (speed bumps were fine). No surprise then that the drop links had failed. Local garage fitted some new ones and all was good. Three momths later, clunking returned. Local garge took a look and noted that the...
  2. T
    Drop link replacement. Which size??
    Hi guys I had some Koni suspension fitted 3 weeks ago and all seemed great until last week when I got some horrible sounds from the suspension at lows speeds. After lots of YouTube, I found a video with the exact sound I am experiencing. (30 secs in is my exact noise) It seems to be the...
  3. P
    T5.1 / T6 / T6.1 anti-roll bars
    Going to upgrade antiroll bars. First are both t6.1 what's difference with t6.1 led and none led roll bars will both fit as I don't have led Second my rear anti roll bar is a std t5 one. Any differences from t5 to t6.1 on rear axle fitment and does lwb make any difference? Tempted on...
  4. N
    Drop links - OEM?
    Just had my MOT done and I had an advisory for a bent drop link. It looks like the OEM one and on checking the other side has been replaced with a non OEM one at some point. I’ll replace both sides but my question is…..do I stay OEM or is there a better alternative that people have tested and...
  5. N3DXT
    Sold So Low VW Transporter T6.1 Longer Drop Links - for Lowered Suspension
    Bought these from Transporter HQ for my T6.1 but I'm not really running it that low at all so kept the standard VW ones on there - £20.00 POSTED
  6. JamieCkombiT6
    T6.1 Van Slam Coilover Kit Meyle HD Top Mounts & Droplinks
    Has anyone on here got this kit from travelinlite- transporters Is this everything needed for a suspension upgrade/lowering Looking for advice on this pack as I will have to get a local fitter/garage to install...
  7. A
    ARB drop links, what's the trick? / secret.
    So running a t32 lowered 40mm on CRS supplied (self fitted) koni shocks and springs. When we first fitted them we managed to thread the nut on the drivers side ARB drop link. second attempt and we thought it was all good but it started knocking and on further inspection the ARB was loose so it...
  8. Ned Kelly
    Broken Drop Link
    I recently replaced B14 with Air Lift 3 H and had a height sensor disappear on me. On investigation, it looks like the drop link has snapped and taken the wiring loom out. This should be a straightforward fix. but what im more concerned about is why the drop link has snapped the ARB's where...
  9. Tourershine
    SoLow Suspension
    I know Solow's aren't new by any means, and several members are already running these bad boys, but as a die hard B14 fan, I wanted to give my take on this set-up. As some of you already know, i'm pretty chummy with the Transporter HQ team. They regularly ask if they can borrow my van for T32...
  10. davek
    Meyle Drop Link Nut Size
    Anybody know the size and pitch of the Meyle Drop Links, two of mine have worked loose, so going to fit locking nut with spring washer
  11. Lukavell
    Alignment issues and Errors
    I've recently changed my shocks, drop links and steering tie rods. I did the front first and the steering wheel alignment was out. Strange I thought. I couldn't understand how it happened so I spoke to a mechanic friend who didn't get it either. He suggested re-aligning the steering wheel which...
  12. Jason Stancliffe
    ARB problem
    Hi Recently fitted H and R ARB’s I must say the handling is much improved, hardly any roll in the corners and the van seems more planted and firmer ride which I like ( have 40 mm h r springs) The problem I have it is a bit crashy / harsh and noisy now over small bumps on the road , not so...
  13. Lukavell
    Tie Rod dramas
    I've been fitting the first Koni front shock and T32 springs today supplied by Sterve @CRS Performance, hard work but I'm nearly done and the next one won't take so long! Has anyone else had to replace the steering rack tie rod when working on shocks/springs? I ask because the torx or allan...
  14. J88arv
    Help: Either Top Mount Or Spring Gone
    Hi all just been to Kwick fit and was advised my passenger side shock is either knackered or the top mount and the other side is going in short it knocks like a bitch continually and needs sorting as it’s doing my head in. can anybody shed any light on similar experiences or advise on how to...
  15. goldeneye243
    H&R ARB - shorter drop-links??
    I'm getting my coil overs and ARBs fitted today - The mechanic has asked if I had any shorter ant roll bar links. I wasn't sure - Have I missed a part??? I'm having Stance+ Ultra coil overs and H&R ARBs fitted...
  16. Simon228
    Drop Links. When And Why To Use Longer.
    Hi Has anybody changed there drop links for longer ones when fitting coilovers or air ? My coilovers are adjusted as low as possible but still need another 10mm or so to level it out with the rear. I didn’t know if changing these would have an affect on ride height.
  17. catfood12
    Lowering The Front Suspension - Surely I Need Longer Arb Drop Links ?
    Mates Just installed an H & R ARB set. My van is running lowered VMaxx adjustable coilovers. Bought a set of shorter drop links to avoid any binding and keep the ARB attitude stock at the lowered level. It made sense at the point of purchase, I assumed the ARB was higher up and had links down...
