Evening all.
Apologies if this has been asked before, I have done a quick search but can't find a definitive answer.
The time has come for my EGR cooler to throw the expected leak. The one currently fitted is part number 04L131512T.
My question is, is 04L131512CF interchangeable? I can find...
I just replaced the EGR valve and cooler on my CXGB 2016 T6, and it seems to be running well. Do I need to do any calibration / adaptation with VCDS or similar?
So I bought my t6 last month, from a dealer in Essex.
On the way home the coolant light came on. Topped it up and it happened again a week later.
I’ve just had a Vw specialist look at it and this is his diagnosis
“Removed front EGR connecting pipe and visually inspected with...
Hi this is my first post on ,been just using tofind out all about my Dreaded cfca engine in my T5 sportline 2013 , have spent over £7000 trying to get it fixed.What a want to find out is the my engine the right one that was ment to be rebuilt or have I been conned .The number on engine is 03L...
Hi Everyone - great to be a member here - a shame i need to post for your help
I have a T6 2.0 TDi 104 ps I've owned it for 5 years and in that time I've had the EGR flushed under warranty once. Then had it replaced by VW dealership and then flushed twice more (as warranty work after the...
Hi Guys,
New to the forum as a contributor but have found the threads immensely useful over the years, finally time to get involved!
We have a 2018 204 DSG 4Motion Kombi in our workshop at the moment that is losing coolant. I've read a few threads on T6s with this issue and once a physical...
Code P0401 and engine light on - have been to three garages and all suggest EGR / cooler need replacing…….again! Last one has lasted about 10k. Engine light has turned itself off twice over last month or so lastly after not driving the van for a week but returned about 100 miles into...
Hello i have some problem with my t6 2018 CHXA after replace Egr+cooler and the pipe on the backside. after a Quick drive like 3-6km i get 2 faulty codes
P4020
P0101
What can cause this problem?
Hi all, new to the forum (introduced myself over on the new members bit) and looking at purchasing my first Transporter for a camper conversion.
I'm looking at a 2.0L TDI (180bhp) with highline spec / 2015 (15 plate). It's on sale in a dealership, but is being advertised "as seen" as they have...
Just wanting to improve my understanding..
If an EGR Cooler is blanked off.. Will this mean that that the DPF blocks up / blocks up quicker?
Also, will the DPF still continue to function as VW intended / function effectively without adversely effecting the engine?
Understand that the...
https://www.darksidedevelopments.co.uk/products/vw-transporter-t5-1-t6-egr-blanking-kit-for-2-0-bitdi-cfca-engine.html
As per link here are some Darkside Developments T5 T6 EGR cooler blanking plates for 2.0 bitdi 180 CFCA used on my engine for a few months. All good re useable condition as...
Hi guys
Had a few of these EGR low flow faults lately on different vehicles. On one vehicle i removed the cooler and tried to clean in but with no luck. The cooler is a bit different so I decided to have a look inside and discovered why you’re wasting your time trying to clean them out. There’s...
Hi all, I know this is a long talked about subject but I have found my dream spec van but it’s an early T6 BiTDi with the ‘C’ revision EGR (I asked the dealer for the code on the EGR!). My thought is to go to the dealer with an oil test kit, send it off to be tested, then if it comes back bad...
Hi All, looking for advice from you good knowledgeable people …
T6 66plate 2.0 tdi t32 122,000 miles full service history owned by me one year.
Saturday AM I’m Driving home to U.K. in the south France the red coolant light comes on. Pulls over and I can see coolant below minimum so added in 2...
Hi all!
Firstly, sorry for the long post but I could really do with some help!
I have recently had my EGR cooler replaced at my local VW garage on my 17 plate T6 California.
Thankfully VW have paid 100% of the bill as a good will gesture which I was absolutely delighted with considering it...
Yesss, one more of this :)
I noticed there where already quite a few threads like this. My EGR needs replacing and unfortunately I don't have the full funds for getting it changed by a mechanic atm. I used to work in cooling and heating systems so I know a bit how to work with my hands.
THe...
Hi can any one help me or point me in the right direction looking for torque settings for Egr cooler and pipes ect and rear and front brake caliper discs ect thanks
Have you had a leaking coolant issue resolved?
Please use the poll to tell us what was the cause.
If your resolution is not listed please add a reply and we'll add it to the list.
Please not discuss you issues in this thread (they will get deleted, start a new topic in the appropriate area)
