Hi I'm new to t6 ownership but recently my drivers side window will go up down up down many times before you can shut it frustrating when raining any advice would be fantastic
the passenger window won’t work from the passenger door button
Works fine from drivers side and on the key fob
Iv tried a cheap aftermarket button but that didn’t work either
Any ideas please…. I’m getting grief off the wife when she has to ask me to put the window up and down
Many thanks
Possibly old news to everyone but….
I was thinking my new (to me) van was having electrical gremlins when the auto window up wasn’t working when driving along just now.
I thought to myself, I must scan and see if I can reset that with Carista when I stop. I glanced into the little cubby hole to...
I've a old 2006 transporter but I have a t6 dash installed I think the t5.1 electric motors will fit on std t5 windows . ?
I also have t5.1 highline bcm instilled mainly used for the heater controlls to move the heater flaps ( yes long story )
I'm assuming the t5.1/ t6 window switchers are the...
hiya folks,my driver side window has stopped going up or down,I can hear the motor working but I've had to push it closed by hand,before I pull the door card off,is there anything I should be looking for? Thanks
My van starter battery started to die and wasn't holding it's charge then it went flat. I charged it up so as to start the engine. I bought a new replacement battery which I fitted - so far no problems. I then found that when I locked the van first click, then on second click and hold on the fob...
Anyone have any idea please
T6.1 Symptoms….
Passenger window fails to operate on either switch. If you leave drivers door window open and try to lock with remote the doors lock but the drivers window fails to shut. Also mirrors fail to spin up on lock. Also msg on startup on touchscreen...
I’ve disconnected the battery to fit my new steering wheel but the auto windows dont work and also the windows on the key fob don’t either?
I can’t remember the process to get it all back up and running again?
Please help
Cheers
Hello. My 2021 transporter passenger window keeps bouncing back when I try and close. I have silicon lubricated it to see if that would help and also tried the 5 second switch hold to reset unfortunately neither work. Also when I hold the lock button on my fob for the extra few seconds for the...
I recently had the driver's door outer window seal replaced under warranty as it had a gap. I questioned the passenger side and was told it was fine, though after recent rain it's clearly letting a lot of water through where the angle changes near the front of the window. A friend mentioned that...
So I was working on the van to fit a Vankraft hinge to the passenger seat. No key in the ignition. I was nowhere near the drivers or passenger door window controls. Not working on any electrics at all, just seeing how the seat fabric is removed and what spanners I needed. Suddenly both driver...
New to T6.1 kombi ownership (2nd hand) and a problem has arisen!
I’m getting an electronic child lock fault come up on the dash, as well as front windows not being able to open. Neither switches on either side are working to open window. As I if left mirrors rotated up, they are also not...
Hi there,
I've been toying with fitting a drivers side switch panel to the passenger door in my T6 Caravelle.
The initial plan was to get a passenger side central locking button but none of the options I have found for the single window switch panel have the central locking buttons. So I've...
Hey guys! On my t6.1, the driver window is unresponsive (and left open). It has happend while I was using it. I has open it, so it went down, and right away, I tried to close it and it was unresponsive. The passenger window is fine. Interestingly, the confort open with the remote key doesnt do...
Hi Guys,
I have something new for sale that will make your cabin a little bit more blingy, but bring the style in line subtly with the rest of the cabin area.
Below shown on the left side, the original switches and on the right side the new chrome tipped switches;
Chrome Tipped T6 Caravelle...
Had the battery off ..(No problems before )
Know : mirrors won’t fold on fob
: also windows do not work on fob ...
I have done the window reset both ways up / hold /down & hold to no avail
anyone any ideas please ? .
Hello,
We have from time to time water that gets through from the drivers door window (nothing the other side..). This comes through the doorcard and drips down onto the lower door seal.. when i open the door this releases and i can see dribbles from under the door card. @Pauly any ideas of...
