engine bay
  1. N
    Cleaning the engine area (cosmetic)
    I’ve just got my first T6 and would like to tidy it all up and ensure it’s in the best possible condition inside and out.. While service history shows good/regular checks (for 125k) part or buying the van was to learn more about them too, like the engine and the electrics Lifting the bonnet...
  2. sipep
    240v cable separately from 12v (cable route)
    Hi all, I've had a little search in the forum but can't find my answer. Is there a secondly grommet other than the one behind the starter battery? I want to put my 240v hook under the bonnet but someone said mention that the 240v should be keep away from the 12v. I already have a 12v cable...
  3. H
    [Resolved] Help please T30 will not start - corroded main engine ground strap
    Battery fully charged reads 13.7v after 10 seconds with a heavy duty discharge tester the battery still reads 12.4v and the tester says it is in the green. (The battery was disconnected from the vehicle for this test). My feeling is that the battery is fine but that there is something wrong...
  4. Pedro20001
    T6.1 under bonnet electrics
    Hi all, I need to add another +12v feed from the starter battery terminal , what's the best way as there isn't much room available underneath the nut on the terminal. Any suggestions please? It's a 2021 t6.1. Thanks in advance
  5. marsie
    washing engine: yes or no?
    I have just bought a t6 and the inside and outside are spotless but the engine bay is a disgrace (dusty crap, not oil). will I be safe to give the engine a blast with the pressure washer or is it a bit of a gamble on VWs? I am used to land rovers and when they get dirty there is no problem with...
  6. DaveyB
    Engine degreaser. Any recommendations?
    Ok, so it seems that I have had a massive noddy moment. A month ago I popped a litre of oil in the van to top it up as the MFD had told me to do so (this is quite normal for my van, I have always found it needs a top up in the year it is not serviced with it being on long life). Fast forward...
  7. TEESIXY
    Water leaking out of this [A/C drain]
    I've not been using the van much lately, and it can be parked up, sometimes for weeks in a garage. Whenever i do use it though, there always seems to be quite a lot of clear water where the van has been standing- usually below the front bumper area. I've always assumed that the underside of...
  8. markob
    Victron Blue Smart 12V / 15A Charger - Fit next to battery?
    Sorry if this has been answered before.. Is it possible to mount the above charger (or the 25a version) next to the main battery under the bonnet ?
  9. O
    T6.1 engine bay cable routing
    Morning. Apologies if this has been asked but tried searching and couldnt find what I was looking for. I’m adding a split charge system and need to get a cable to the engine bay. I’ve seen a vid on a T6 which seems to show an unused grommet under the glove box/next to the starter battery but...
  10. moodsterT6
    Victron MPPT under bonnet?
    Anyone have or considered fitting a Victron MPPT under the bonnet? specifically in the battery compartment which in my case is a T6 Caravelle. I’ve done some research, a thread on the Victron community forum states they don’t recommend it due to heat and its IP44 rating but I would argue it can...
  11. A
    Water dripping from behind glove box
    Water is dripping from behind the glove box on my 2016 T6. I removed the glove box for access and found an unusually large amount of condensation accumulating on the bottom of the HVAC unit. Any ideas what might be causing this?
  12. Depron Donkey
    Retrofit front PDC
    I have rear park and camera and want to add fronts. I know I have to replace my 4k PDC controller for an 8k one (5C5919475) and also need another bleeper (8E0919279) four sensors (5Q0919275B) plus brackets (7E5919493E/4E / 93D/94D) Anyone know if this loom (Kufatec) will reach the replaced PDC...
