engine fault
  1. Jacobwilliamshort
    Engine Oil Temperature Fluctuation
    I have a 2021 VW T6.1. My oil engine temperature will intermittently start fluctuating and not settle on a temperature. This resulted in the engine management light (the coil warning light) coming on, on one occasion, and the start stop and ACC being disabled. However, leaving the vehicle...
  2. S
    Engine won't start- Failing HPFP?
    Hi, I've got 17 plate 2.0L Diesel (CXGB) T6 that has decided it doesn't want to start now. There's no fault codes coming up. I suspect the HPFP is to blame. I've got a known EGR valve fault that's been on my to do list to fix, but I don't think this is causing the starting issue. The EGR valve...
  3. G
    Fault code P011100
    Can anyone shed any light please on this error code P011100 Air intake temperature sensor1? (2017 2.0 CXGB) I have reset the management light and it stays off for 3-5 days then its back on again. When the eml is on it still drives absolutely fine with no noticeable difference at all. I have...
  4. M
    EGR issues yearly flushes needed
    Hi all, Bought my bitdi in 2020 at 40k miles(67 plate) Few months after not doing much driving i had engine (EGR) lights on (P046C00, P040100). Thought it made sense as i did not drive enough and no motorway miles really. Then i started using it mainly on motorways and i had to have a flush...
  5. M
    2018 204tdi Needs a new engine?
    Hi all - Long time lurker looking for a bit of a sanity check A bit of background 2018 204 TDI – DSG – 4Motion – CXEB Owned 4 years since 9000 miles, now on 51000. Serviced at independent, back to VW for anything above that. For the last 10,000 miles its been progressively using more oil...
  6. B
    2004 LWB 2.5TDI Coolant Flooded Engine
    Morning fellow VW folks, I am reaching out for some of your expertise and guidance on what I should do next, In Dec my much beloved Van decided to dump its coolant, I at first thought it was just a leak, however it turned out to have been a leak into the Engine, I managed to get it to a...
  7. C
    Engine cut out and steering fail when in reverse or low gears
    Hi, We bought our 2018 T6 102 T28 last September, 3 weeks later the engine cut out as I was coming around a bend to stop at traffic lights. Power steering failed and sent me into the opposite lane in front of oncoming traffic. Since then it’s been a consistent intermittent problem…. Happening...
  8. A
    Engine Cut Out At Speed !
    hi all, just a question to all t6 owners, i have a t6 4 motion 204 ps dsg, and it has cut out on me 3 times, 2 weeks ago i was on the motorway and pressed the throttle fully and the engine cut out on me in the 3rd lane, i was able to get to the hard shoulder and restart and move on. a bit scary...
  9. lough90
    Engine cuts out when slowing down to a junction.
    Has anyone had an issue with the engine cutting out when you slow down to a junction. it doesn't happen a lot but when it does its a little bit of a bum clenching moment as the steering goes extremely heavy. Once i was pulling in to a lay-by to take a call and as i slowed down and dipped the...
  10. TEESIXY
    Safety issue- Engine dies when changing gear.
    I've started this thread because it seems to be a different issue to one already posted, where the engine dies at low speed. Just had the biggest scare of my life- going down a steep'ish hill, with a 90 degree bend at the bottom. Doing about 35mph in 4th gear. I started to change down to 3rd...
  11. HHO
    Engine shut down
    Bit of an odd one this. Driving along road this morning (from cold start) just pulling onto a traffic island about 200 yards from my house and the van appears to "stall" whilst I'm travelling about 10mph. I was stuck accross two lanes for about 20 seconds while I restarted. Message on dash...
