Hello! I recently bought a T6, had it about a month now and I’ve noticed a ticking noise when driving and under acceleration.
Noise goes when I dip the clutch travelling at speed, but then comes back when I re-engage. It’s 150bhp 68plate with 84k miles.. anyone had similar noise?
2019 Startline Manual 84bhp
I've had a hissing noise from what sounds like the drivers side of the engine bay for a little while now, although only happens under load so hard to be certain. The van had an EGR insufficient flow error code so I assumed it might be linked to this, having done some...
Hi Everyone,
I have a 2017 DSG T6 340, with 90,000km (56000miles) on it.
I just wanted to get some opinions on the engine / gearbox sound, I have a couple of concerns. I think there might be a slight DMF noise going on although not as loud as others I have heard online, and also the...
Hello,
My transporter t6 5spd manual 84kw makes this weird gurgling noise when changing gears. It has new dualmass flywheel and clutch fitted at vw dealer. Its coming under my feet and i can hear it in cabin.
What could it be? Youtube link
Up
I have a T6 and the noise in the cabin is to high to be comfortable for me. Below 100 km/h it's mainly the road noise that's disturbing, above 120 km/h the wind noise takes over. The road noise varies quite a bit depending on the type of asphalt.
It is a 4MO panel van with left and right...
I’m currently on a road trip around Europe and only half way into my trip with probably another 5000miles before I get back to the UK and my engine seems to have just started juddering.
I noticed it the other day while first starting the engine and thought maybe it would be fine once i got...
Hello,
I'm new to this forum and I have had my 69' T6 150 manual for a few weeks now and noticed a ticking or clicking noise from the engine with the engine running. It's there from cold or up to temperature.
The van has done 8000 miles.
The noise is not really noticable when driving but when...
i’m a bit worried. 2016 150hk diesel with DSG. 28.000km on the clock. Engine starts and runs good, but when accelerating i can hear this ‘clattering’ noise. Its not very loud and initially i believed it was something loose and rattling, but found out it only appears when accelerating with...
i can hear a kind of 'ticking' noise a bit like a chain sound, mainly in low gears and disappears when I change to 4th 5th or 6th.
Also the sound stops when I dip the clutch it winds down. It's not loud but I can hear it.
Been back to the dealers twice and both times they said that they can't...
So 6000 miles on my t6 and start getting ticking/ squeek like belt sound, vw took it in and had it a week and changed aux belt and pully, gave it back drove out car park fault not fixed, told me to use it for 3 weeks as had no courtesy vehicles but i refused kicked off and they took it back in...
