1 x Pair of little used Eton Plug and Play Speakers for sale.
Great speakers, like new.
East to fit and work of the Factory Head unit.
No Amp needed.
https://www.ebay.co.uk/itm/233869128877
Hi, ISellong a set of Eton UG T6 F2.1 speakers. These are high quality speakers and a fantastic upgrade. Loads of posts about them on the forum.
I have removed these speakers from my van. Eton website information
These are plug and play. I will also include the rubber cones.
All that is...
We have been manufacturing underseat enclosure for Transporters for years, based on a JL Audio 10" sub
We are also about to do a active one
Many on here are running one...
What I am trying to achieve.
I have got a Discover Media head unit and Eton pnp speakers.
I want to add an Audison AP5.9 Bit amplifier.
I have also got an Audison Harness:
and ani ISO EXTENTION INPUT 260 CM/102"
I have fitted the harness to the back of my head unit. and If I plug the 2...
Just had a quick search around the forum but not mentioned, so, just spotted a set of Eton 3-way speakers at Nottingham car audio, for the T5. Any reason this can't be shoehorned into the T6? Seems to have a small speaker below the tweeter in the a pillar?
Anyone know it?
I have test fitted DNX9180DABS today.
At the front I have got Eton 2.1 fitted with some Silencoat to keep vibrations down. The rear speakers are Kenwood coaxial 17cm speakers.
Kenwood does not sound as good as basic VW headunit. I have tried all sorts of adjustments, but bass wise Kenwood is...
Due to a possible change in direction I am thinking of putting a pair of plug and play Eton speakers up for sale.
Plenty on info around on the forum.
Please let me know if you are interested in them?
Cheers
I am increasing frustrated by the poor sound quality of my Discover Media satellite navigation system in the Caravelle and I was wondering about upgrade options for a fully functioning HU that will run all the VW functions.
Apart from the above Kenwood model are there any others or is this...
Fitted it tonight. Followed our German friends step by step guide. Got the whole set up from Ars24 including all sound dampening - unbelievable results. What a really cost effective upgrade. Doesn't sound like a van with a mono tinbox - sounds like a luxury car inside the cab now...
The Eton Vw T6 kit is the only 8” door woofer and pillar tweeter replacement that is a direct fit from a manufacture, Ideal for diy fitment
They feature 3ohm coils which make them efficient enough to run off a factory head unit, and can also be amplified
We can offer them for a short period...
Hey guys,
So would like a bit more from the vans sound system. Mine is a 2016 Kombi with the standard satnav headunit. I want to keep this as it does what I want but I would like a little bit more sound quality. Without spending £££’s is there a route that people have done? I’ve been keeping an...
Looking at swapping front speakers. Without stripping door first does anyone know what sizes I need to be looking at? Also any recommendations? Ta peeps
https://absolut5.co.uk/
https://www.t6forum.com/threads/review-absolut5-audio.21632/
Absolut5 only use the best tried and tested products out there for your pride and joy..
We only supply Pro Fit Facias for the T5.1 and T6, the best finish and fit, we have been using these for over 4 years...
we have the first set of Eton T6 front speakers in the Uk
These are truly the first easy to fit front door and pillar upgrade,
German quality featuring 8” door woofers and exact fit pillar tweeters, highly sensitive so ideal for factory and aftermarket headunits.
Not cheap at £449.00 but...
Right, so I've fitted a dash cam and successfully pulled things apart and put them back together again so..... Now I'm fancying taking the door cards off and fitting some new speakers and applying a touch of Silent coat or similar. Any tips please.
Would you recommend applying the sound...
