factory fit aux battery
  1. O
    Disconnected the leisure battery - now lots of fault codes
    Hi Guys, I have a VW T6.1 Transporter with a factory leisure battery. I was working on my van earlier today and had the passenger seat out to lay a cable to my starter battery (not connected). When I put everything back together, seatback in and connected up the leisure battery, I'm getting a...
  2. Eddie Sutherland
    Could I take a feed from here for DC to DC charger
    I have this lot under passenger seat of new van week old and I am pondering if I can feed DC to DC charger from here for lithium aux battery. I haven’t had a chance to get meter out and poke around yet. I am still yet to figure out what it feeds also. (Updated to state correct tech being used)
  3. Dans_t6
    Factory Aux Battery Relay T6
    Gday from down under Does anyone know if a faulty aux battery relay from factory would cause the battery light illuminate on the dash. When it does do this I can hear the relay tick as the light comes on. After starting the van, about 30 seconds later the battery light comes on which as a...
  4. TallPaul_S
    Upgrading the Factory Leisure Battery set up (+ additions)!
    This is my current set up in my 2018 Caravelle, a mess of wires of a Factory specced Eberspacher Auxiliary air heater and 2nd battery, plus a few extras fitted by the previous owner, all under the passenger seat: This is the wiring diagram as it sits: I've got the standard split charge...
  5. B
    Webasto air top 2000 stc external bracket drawing.
    Hello everyone. This is my first post here. I have just bought a 2016 vw Multivan that I plan to use as a weekend camper. Some of my planned modifications are to install a webasto diesel heater under the car. I am trying to find measurements and drawings, possibly a 3D drawing, for the...
  6. EAN
    T6.1 with Factory fit 2nd Battery Cab Socket Poll
    On my 2023 T6.1 both the cab sockets were factory wired to the factory fitted leisure battery. I‘d like to know if this was a standard change from T6 to T6.1s (2019 onwards) or whether it “just depends” on equipment fitted. Advice is often that you can charge the starter battery from one of the...
  7. G
    10mm2 cable Fuse Box SH
    Under my passenger seat I have what looks to be a 10mmsq cable which I’m lead to believe can be used for a DC-DC charger, negative coming from chassis. I was originally thinking of a Victron 12/12/30 unit which would be mounted in a cupboard I intend to make and located under the non sliding...
  8. Merryman
    For Sale 100Ah Banner battery (used twice!) + battery bits
    - Banner 12 volt, 100/110AMP Battery used twice, so has many flat to full recharges left i.e.100 plus. £100 currently being sold new at around £175 - Battery Box and belt £10 was new £24 - Battery Clamp £10 was new £29 Collect from NR95AT near Norwich A47. Or occasionally...
  9. C4S
    2nd battery under driver seat useful ?
    All, I specced my van with a few extras when I ordered it. One of them was a 2nd battery under the drivers seat, I am intending on using the van as a camper at a later date but for now it’s primary use is for work and a day van. At present nothing is running off this 2nd aux battery but I’d...
  10. R
    Factory Auxiliary battery wiring
    Hi. I have a the set up as shown in the photos and would like some info if anyone can help please. Where does the feed into the split load relay come from as it is not connected to the battery terminal, and what might be the length/ route for the cable? I would like to fit a proper leisure...
  11. Andnik
    Unknown wires on OEM Aux battery
    Hello All Electrics Specialists (Dellmassive) I am fitting a solar panel / Renogy DC DC Charger under the seats with a Renogy Lithium Battery (OEM Aux Battery) I have discovered some odd wires under the seat and would like to know whats going on. Non OEM Towbar electrics by prevoius ownership...
  12. r00ps
    T6.1 factory aux battery split charge relay upgrade & solar panel install.
    Hi, I had the factory fitted aux battery ( under a single seat with swivel base ) fitted to my T6.1 with the intention of using it as a camper leisure battery. After getting less than impressive performance and reading about how the split charge relay is a pretty bad charging method I wanted to...
  13. B
    The battery under the passenger seat
    We have a T6 van which is going to be used for transporting dogs about as we have more dogs then our current caddy can carry To keep them cool i have fitted a roof fan (thread to follow) This will be the only extra stuff that is electric that will be fitted to the van so i see no need to go...
  14. Drifterman
    OEM Aux Battery Wiring?
    Good evening all I'm hoping somebody will be able to point me in the right direction quite easily - I want to connect a leisure battery to my new Renogy DCC50S charger. My initial thought was just to run a fresh cable through to the starter battery in the engine bay, but I've found some cables...
  15. C
    Connecting a leisure battery (T6)
    Hi I have a factory fitted leisure battery on my 2018 T6 Kombi, however it doesn't appear to be connected to anything. I don't get a relay click from the leisure battery when I turn the ignition, nor do I have any 12v or 240V sockets in any of the pillars. I think I need to find a conversion...
  16. W
    Factory Fitted Second Battery
    Hi. I’m away now for the second week in my van and it seems my factory fitted second battery under the passenger seat is draining as well as my main battery. I haven’t run the van since arriving. I assumed the second battery was like a leisure battery so am puzzled why the main battery should...
  17. T
    Swapping from OEM 2nd battery to dc-dc. What to do with the VSR / relay
    I know this subject has been covered to death but I don't know what you do regarding the OEM relay. So my van had the 2nd battery and I am planning the electrics going forward, I am going to put a lithium under the driver's seat hopefully and use the OEM wiring. So what do you do with the...
  18. T
    Pax Seatbase electrics ex RAC
    So I have had a look at other threads but couldn't find the answer, does anyone know what these wires/ fuses do under my passenger seat please!?
  19. C
    T6.1 pax seat factory-LB wiring
    Hi, I'm new to the forum and have a question regarding my 2022 T6.1 Kombi. Under the single N/S passenger seat of a RHD Kombi is a long slim fuse box. This is fed by a fairly thick red wire which is permanently live and terminates and splits into a slightly thinner one and three thin ones which...
  20. EAN
    T6.1 12v cab sockets with factory aux battery
    Have looked at previous threads and some seem to conflict with what I’m finding. 2023 T6.1 Hillside Birchover Classic campervan; uses standard VW factory fitted aux battery fitted under passenger seat. I’ve just measured the voltage on both the upper and lower cab 12v sockets both with the EHU...
