flat battery
  1. Phil TL
    First post, first camping trip, first user error(?)
    Hi everyone, thanks for letting me join, looks a great community. My wife and I picked up a 2023 Hillside Leisure Birchover Exec from a dealer in January. 500miles on clock, just been dealer showroom van. Very nice van, 150ps dsg highline T28, good spec camper. Sorry for long first post...
  2. D
    Suggestions for Flat Battery Investigation
    Merry Christmas everyone! I hope you are all enjoying your turkey dinners, but if you should have a few idle moments this festive season I would be grateful for suggestions on how I might diagnose a flat battery problem. The van is a 2016 T6 converted in 2023 with a leisure battery...
  3. S
    Battery drain or dodgy battery?
    Hello hope you are all well. I have a 2021 T6.1. Every now and again in the morning it would struggle turning over, but would always start. When this happened the dash always showed "VCC error", along with some other errors (I cant recall right now, but I think it said the senser that the...
  4. AYRGUNN
    Battery dying [Resolved]
    Hi all, looking for some advice. I work away for two weeks at a time and when I get home my battery is dead. There are no lights left on or anything like that so wondering what could be draining it?. I have a usb port and reading light installed with 4 down light in the back. Thats all thats...
  5. T
    Fuel consumption skyrocketed since flat battery
    My battery was flat when we came back from holiday so after a recharge my fuel consumption is so bad it’s almost like it’s leaking somewhere. £30 of fuel got me 38 miles. No drips that I can see or smoke . Any ideas ??
  6. O
    Total loss of power and flat battery
    Had a total loss of power crossing a roundabout, engine seemed to have stalled with suddenly jolt, tried to restart but low cranking speed and then totally flat battery. Aux drive belt seems to have stripped outer edge, this was only replace a week ago. Also found this on the driveway on my...
  7. L
    Intermittent Battery warning light
    Hi folks, Battery warning light came on dash as driving home Wednesday night. Thursday morning it stayed off. Took it to a garage to check it over and they said the battery is fine, but obviously could be the alternator. Drove to work (25 miles) and it stayed off. As driving home last night...
  8. F
    Flat battery after 3 days parked up.
    Hi everyone brand new to forum Vehicle details 2016 t32 t-line 2ltr tdi 30,000 miles. Camper king conversion.stood for 3 days "battery flat" iv only had it couple weeks purchased van from Marquis lesure with a 3 year warranty. Rang them and they told me they would check it out. I put some miles...
  9. I
    Leisure Battery - accidentally drained, what next?
    Hi all - need some advice please. We have an Autohaus Ashton T6.1 camper conversion, 2022. Having not used the Webasto diesel heater for months, I did a quick test of it a couple of weeks ago. It worked fine. I turned on the main control panel before testing the heater as I assumed the leisure...
  10. D
    Interior lights are timing out really quickly
    When I open the rear of my T6.1, the lights fade out after about 10 seconds. They didn't used to - they used to stay on for several minutes. I've now knowingly adjusted anything. How do I increase the time-out?
  11. J
    Fuel Gauge issue since flat battery
    Hi all I wonder if anyone can help, my T6 had a flat battery today and wouldn’t turn over, I put it on a trickle charge fo a bit and got it started but now my fuel gauge is not showing any increments the fuel light is on and it’s reading 0 miles in tank ? Has anyone ever experienced this before...
  12. G
    van Parking Lights..
    Just sharing a tip, if like us you throw some of your excess baggage onto the drivers seat when camping in the van, just be mindful you don’t accidentally, unknowingly knock the stalk activating the parking lights, like we did, not sure how long they were on, definitely all night, probably a lot...
  13. voltswagon
    Sudden cut out. Esc & Acc error - No crank - Nothing on diagnostics
    Hi not sure what happened. When to pick up fish & chips last night in the -2 weather drone for 20mins fine and on way home it suddenly cut out with no warning. Managed to stop at side of road & called AA. This is a video of what was happening. The errors are: - ESC (stabilisation error) -...
  14. H
    Van wont start after sitting for a week
    Hi, I have a VW T6 65 plate 2.0L Diesel which hasnt seen much use over the winter bar the occassional outing as a second vehicle. Recently its not been starting due to the battery being too low, the van tries to turn over but isnt enough to start it. I had a service in October and as part of...
  15. Shaun Witts
    TSI flat battery - starts with a jump but dies immediately [Resolved]
    So flat battery this morning. Dash lights OK, and the remote unlock worked OK, but dim lights when the key was turned and the battery monitor was reading 11.15v. Its a 2018 van and the original battery was replaced under warranty within the 1st year (with another Moll that I suspect they got out...
  16. C
    Folding mirrors not working after battery replacement [Resolved]
    My van starter battery started to die and wasn't holding it's charge then it went flat. I charged it up so as to start the engine. I bought a new replacement battery which I fitted - so far no problems. I then found that when I locked the van first click, then on second click and hold on the fob...
  17. D
    Battery drain (sorry, another thread)
    Hello I have browsed through other threads on the same theme, but looking for help with battery drain. When I picked the van up 1 month ago, the battery was flat. Jump started and it has been 'fine' since (although I was driving along one dat and noticed the red battery light on the dash). Last...
  18. Glennpea123
    Flat Vehicle battery [Resolved]
    Transporter T6 Hi all, my battery has gone flat again. It was new a few weeks ago because old one was old and kept going flat, now this new one has. Put on charge this morning and alarm came on and i couldn't turn it off..eventually stopped. Am i doing something wrong with how I leave the PMS...
  19. M
    Engine won't turn OFF after flat battery....help :-)
    Hi all, I recently took a week's holiday and returned to a flat battery, no big deal I thought, it's a 2016 T32 probably with the original battery, so a new one required. However, I jump started it and drove around for half an hour, got home stopped, removed the keys and engine was still...
  20. Jonni2rets
    Flat battery been jumped started query
    Hi all, the wife had a flat battery on the t6 after she finished work and one of her friends used jump leads to get her started but they used the negative on the battery. I was told not to use the negative terminal on the battery but she didn’t know any different, would this cause any damage or...
